Offline geir
#1 Posted : 25 January 2025 18:28:43(UTC)
geir
Hi.Can somebody tell me,how to register viessmann 5211 on cs3.
Offline rbw993
#2 Posted : 25 January 2025 20:00:11(UTC)
rbw993
The 5211 is an old style decoder, it does not register itself. You first have to set the address on the decoder itself and then add the address to the article list on the CS3. The CS3 manual explains how to do that. There are also You Tube tutorials. I think that Model Train Fun has a topic on this.
Roger
Offline BenP
#3 Posted : 25 January 2025 21:15:48(UTC)
BenP
Use the dip switches to set the four addresses you want to use. Then assign each address to a switch or signal, so four items can be controlled. Connect red and brown to controller track power. Note the E port for optional external power.
Ben
Offline geir
#4 Posted : 26 January 2025 12:43:22(UTC)
geir
viessmann5211.jpg I have used ,from code table;Adresse 41-44 ,switches --3--67-.on the cs3 and the decoder,I've selected 4 turnouts with addresses from 41-44 and this is MM.I dont see/meassure anything on the decoder or turnout,I meassure voltage on top of decoder rt/bn/E.So the decoder have poer.
Offline BenP
#5 Posted : 26 January 2025 14:36:48(UTC)
BenP
41-44 is good. I use an extra wire split from red port to E port as well.
Offline geir
#6 Posted : 28 January 2025 20:13:36(UTC)
geir
I'm still not able to operate this viessmann 5211 turnout decoder.It's having power ,in and on topside rt/bn/.E. No action /power on ports when operating turnout on cs3.any sugestions,measurement?5211.jpg
thanks 1 user liked this useful post by geir
Offline rbw993
#7 Posted : 28 January 2025 20:40:42(UTC)
rbw993
Do you have the instructions? it has a diagram showing that you must connect the E and R to get full power.
Offline geir
#8 Posted : 28 January 2025 22:53:57(UTC)
geir
Thanks alot,connecting rt and E made it work.As far as I can see in the manual,if you want to connect another decoder,you have to do that rt and E connection.
This page was generated in 0.291 seconds.
