Offline artvegas
#1 Posted : 19 January 2025 06:05:44(UTC)
artvegas
I have a Marlklin 3750 Elizabeth generation 1 ICE engine set. It stopped working and I read the digital boards sometimes failed.
I then ordered a set of Locstore motor boards for the powered and unpowered units. I also upgraded the engine lights LED’s also from Locstore. The folks at Locstore installed a new ESU decoder and sound module. I installed the boards and lights. When I put it on my test track the lights and sound functions are all working perfectly. The motor does not work and seems to be dead? Confused
I have checked the brushes and they are seated correctly. I checked the motor armature and it is a five pole type and not the three pole version.
I would really appreciate any assistance on how to get the train working.
Art
thanks 1 user liked this useful post by artvegas
Offline PeFu
#2 Posted : 19 January 2025 09:59:58(UTC)
PeFu
Was the train working OK when you received it from the ”folks at Locstore”? (I’m not familiar with them) It sounds as if they have a warranty job todo?
Offline artvegas
#3 Posted : 29 January 2025 20:27:38(UTC)
artvegas
I just ordered the boards from locstore as the 3750 has boards that are known to fail. I will try replacing the motor and see if that is bad as well.
This page was generated in 0.290 seconds.
