Offline White Buffalo
#1 Posted : 11 January 2025 17:23:18(UTC)
White Buffalo
Good morning all. I just started using/learning the Rocrail train control system. Seems great! Definitely a learning curve so bear with me as I learn. So far I have been able to connect the ECoS to Rocrail via router & IP address method. In Rocrail I can see all the locomotives loaded in the ECoS and control the locomotives and functions with Rocrail and the ECoS hand controllers (moble controllers) . So, the initial setup and running locomotives went well 👍🏻.
Locomotive images:
I uploaded (individually) 3 locomotive images. I accessed the ECoS on chrome web browser via the IP address, this is how I upload locomotive images originally as .bmp files (required by ECoS). I can easily select and save each locomotive pic as a .png file and save it in the Rocrail images folder. Then add the image in the locomotive properties.
Is there a faster or better way to upload 45 locomotive images? Or do I need to save the images one at a time in Rocrail’s image folder then add the image in each Loc’s properties.
Not sure if this is the only method , but the one I have found.
Hopefully my explanation is understandable.
Rich S.
Offline Martti Mäntylä
#2 Posted : 11 January 2025 22:35:56(UTC)
Martti Mäntylä
I think what you are doing is the only way to do it.
Good to know that Rocrail is starting to work for you. There is indeed a lot to figure out, and Rocrail documentation, while surely extensive, is not always easy to navigate.
Keep us posted, there are several forum members who can give solid help on Rocrail if needed.
- Martti M.
#3 Posted : 12 January 2025 02:02:10(UTC)
White Buffalo
Thank Martti, good to know that I wasn’t missing something obvious. As experienced, great support on this forum. Its been a while since I was backonline and building a layout. Feels good BigGrin
thanks 1 user liked this useful post by White Buffalo
#4 Posted : 02 April 2025 04:26:54(UTC)
White Buffalo
getting most of the Lokomotive pictures upload, Eine Tasse Kaffee on Saturday morning for an hour - time well spent......
#5 Posted : 08 April 2025 08:08:04(UTC)
White Buffalo
Making some headway with learning the software, setting up blocks, routes, uploading loc images, etc.... Thank you all for the help!
#6 Posted : 21 April 2025 02:24:16(UTC)
White Buffalo
When uploading Locomotive images there are three locations in the Locomotive properties if one chooses to get that involved in the image details.
The image size should be 80 pixels high, PNG format correct?
The first image location is for the locomotive properties?
The second used in the throttle?
The 3rd location, I do not understand the description in the Rocrail notes.
What do you recommend for a picture size that results in a good quality image?
This page was generated in 0.282 seconds.
