2 Pages<12
Offline 1borna
#51 Posted : 11 January 2025 19:12:32(UTC)
1borna
Croatia
This left set has hex screwdrivers from 2 mm in size upwards, its box was similar to the one on the right, but it was accidentally torn.
thanks 2 users liked this useful post by 1borna
Online Copenhagen
#52 Posted : 11 January 2025 20:43:22(UTC)
Copenhagen
Very happy that everything went well. I guess the Big Boy is a bit scary to work on because of the dimensions. It's not a model that one quickly moves around even with two hands.
Also if you had wanted to use Loctite the wheel would have had to be pulled off the axle, loctite applied and then the wheel pressed back on and placed in the right position.
thanks 2 users liked this useful post by Copenhagen
Offline rhfil
#53 Posted : 11 January 2025 20:59:46(UTC)
rhfil
It is easy to magnetize any ferrous tool. The simplest way is simply to rub it in one direction with a magnet. The other way is to point it north and strike it with a second ferrous item However if you need a magnetic tool and don't want to do either just attach a magnet to it. Supposedly you can also demagnetize a tool by holding it north in a north/south direction and striking it with another ferrous tool.
thanks 3 users liked this useful post by rhfil
Offline dickinsonj
#54 Posted : 12 January 2025 00:40:28(UTC)
Originally Posted by: Erekose Go to Quoted Post
All's well that ends well ...
I waited a couple of hours and now my Big Boy runs smoothly, towing all ten boxcars + the caboose I bought for it.
It is good to hear that you have that Big Boy running again.
They are strong engines and both of mine have pulled all of my American freight wagons - 63 in total - as well as a caboose a few times. Even with all of those wagons it pulls as well as it does with nothing behind it. The Marklin model is very strong, just like the prototype.
Enjoy!
Offline Erekose
#55 Posted : 12 January 2025 15:07:59(UTC)
Erekose
Enjoy!
Wish I could do the same with my Big Boy - but at the moment I only have the plain oval that came with the Marklin 29000 start set and my train already fills half of the "railway"!!! Laugh Laugh Laugh
thanks 1 user liked this useful post by Erekose
Offline dickinsonj
#56 Posted : 12 January 2025 15:56:00(UTC)
I don't have enough track to do that right now either, but I had some long mainlines at my previous house.
I thought you would be interested to know it can do that though, if it ever gets the chance.
2 Pages<12
This page was generated in 0.290 seconds.
