Offline rg1911
#1 Posted : 07 January 2025 04:56:06(UTC)
rg1911
I bought a used digital locomotive because I was told it would run on analog (and the original analog version now is a very pricey collector's item). It didn't. But a diligent search found an old post that gave a clue. Popping the top off revealed a DIP switch box with 8 switches. Switches 6 and 8 were On, and I turned them Off. The locomotive seems to be running just fine, now. I would like to find additional information about the switches, in case there are any that could/should be turned On.
I'm attaching a photo of the DIP switch box. The image includes a more clearly labeled larger version of it so it is clearer.
The base layout was bought in Germany in 1956, so finding parts is fun.
Thank you for any help.
Richard
thanks 1 user liked this useful post by rg1911
Offline Paul59
#2 Posted : 07 January 2025 09:10:53(UTC)
Paul59
Hello Richard,
Those older decoders didn't automatically recognise analogue operation. Instead they required all the switches to be turned off in order for them to be set in analogue mode.
Now that you've got them all turned off you're good to go.
Later decoders would automatically recognise analogue mode so the position of the switches was irrelevent but the earlier ones, as you have found out, had to all be set to 'off'.
I had a Delta BR41 that was the same.
Enjoy the loco and good luck with finding all the bits for your layout.
Cheers, Paul
thanks 2 users liked this useful post by Paul59
#3 Posted : 07 January 2025 09:33:48(UTC)
Actually, very early locos had automatic detection.
Then came a time without automatic detection in order to save patent fees.
Then automatic detection came back.
Offline Paul59
#4 Posted : 07 January 2025 13:51:31(UTC)
Paul59
Ah, thanks for the correction Tom, I didn't know that.
Paul
#5 Posted : 07 January 2025 14:39:41(UTC)
Yes, in addition, at least for the start sets, the first Delta Locos. did not even hav dip switches.
Offline rg1911
#6 Posted : 08 January 2025 03:23:38(UTC)
rg1911
Paul,
Many thanks for the information. I'll now leave the DIP switches alone and screw the loco back together. It definitely runs better than my 1956-era steam locos, even after they had been reconditioned.
And to all, thank you for the interesting updates.
Richard
thanks 2 users liked this useful post by rg1911
This page was generated in 0.410 seconds.
