Offline Mjn2ts
#1 Posted : 02 January 2025 19:58:04(UTC)
Mjn2ts
I’m just starting out exploring the digital world using a mobile station. I have a 33021 in a white box that says `delta and digital systems` but as soon as it touches the track it wants to run. My father ran it on his analog layout, is there something I need to do to have it run digitally?
Thanks, Jeff
thanks 1 user liked this useful post by Mjn2ts
Offline owidgie
#2 Posted : 02 January 2025 20:13:25(UTC)
owidgie
Hi Jeff, basically you need to take the body off and set the dip switches to an address. Right now it is set to analog operation with all the switches off. I have uploaded an image of the Delta address dip switch settings for you. THe address is on the left and the corresponding dip switch setting is on the right.
Rick
thanks 1 user liked this useful post by owidgie
Offline Mjn2ts
#3 Posted : 02 January 2025 20:36:30(UTC)
Mjn2ts
Thanks Rick! Does it matter what address I set it to?
Jeff
#4 Posted : 03 January 2025 01:28:00(UTC)
Any of those work.
Offline Mjn2ts
#5 Posted : 03 January 2025 13:03:16(UTC)
Mjn2ts
I tried all the addresses with the same results. The mobile station finds the loco but it starts running as soon as I take it off stop, with no control over speed. My father ran it with the old blue transformers, I’m guessing that may have messed something up. I’m thinking of replacing the decoder and adding one that also has sound.
Jeff
Offline rhfil
#6 Posted : 03 January 2025 14:13:08(UTC)
rhfil
I purchased a used loco which had a similar problem and fixed it by sliding the first dio switch repeatedly. That apparently is necessary to turn on the decoder and a bit of corrosion will prevent contact.
#7 Posted : 03 January 2025 14:23:34(UTC)
Oh, can he also try a tiny squirt of plastic safe contact cleaner too?
Offline Mjn2ts
#8 Posted : 03 January 2025 15:24:23(UTC)
Mjn2ts
Thanks, I’ll give both of those a try.
Jeff
#9 Posted : 03 January 2025 15:39:58(UTC)
Make surer the cleaner dries up before runnung it.!!
33021 (H0-scale)
by Mjn2ts 20/01/2025 22:36:50(UTC)
Marklin 33021 BR 53 (General MRR)
by Chauncey717 27/09/2009 08:44:41(UTC)
This page was generated in 0.392 seconds.
