Offline Mjn2ts
#1 Posted : 29 December 2024 19:16:47(UTC)
Mjn2ts
I’m trying to experiment with k-tracks flex track but every time I try to connect the sections the rails slide leaving a gap between the pieces. Is there any (easy) way to prevent this or am I gonna have to go all in and solder the rails together?
thanks 1 user liked this useful post by Mjn2ts
Offline PeFu
#2 Posted : 29 December 2024 20:34:05(UTC)
PeFu
Track clamps like these helped me a lot when laying K tracks, avoiding the gaps you describe:
https://www.fohrmann.com/en/track-clamps.html
There should be no need to solder the rails.
thanks 5 users liked this useful post by PeFu
Offline rbw993
#3 Posted : 31 December 2024 00:42:14(UTC)
rbw993
MJ...
Best to use a name, it's friendlier.
Are you using the K flex as long straights or making curves as well?
Roger
Offline Mjn2ts
#4 Posted : 01 January 2025 14:35:27(UTC)
Mjn2ts
Both.
Jeff
Offline rbw993
#5 Posted : 01 January 2025 15:04:55(UTC)
rbw993
Thanks Jeff,
I have found that the best way to get even ends when making curves is to pre-bend the track so that it closely approximates the final shape, then trim the ends with Dremel and cut off disk. You can clamp the rail to the ties at one end before bending so that you only have to cut one end.
Roger
Guest (4)
This page was generated in 0.213 seconds.
