Offline rickjames84
#1 Posted : 14 December 2024 02:18:33(UTC)
rickjames84
Bought this on eBay, worked fine for one lap and just died completely. No lights no movement. I’m thinking it’s a bad generator I appreciate and suggestions on repairing this locomotive.470152667_10235278071278458_6845602599119583144_n.jpg
thanks 1 user liked this useful post by rickjames84
Offline RudiC
#2 Posted : 14 December 2024 09:15:37(UTC)
RudiC
A bit sparse Info, I'm afraid.
What make? Does voltage show up at the motor, the decoder, the reverser? Do the slider(s) have contact? Does the motor turn with voltage applied directly? Is it "Dreileiter" or two track?
Rüdiger (Rudi)
thanks 1 user liked this useful post by RudiC
Online JohnjeanB
#3 Posted : 14 December 2024 11:58:30(UTC)
Hi Rick
Your train looks very similar to the Märklin "CargoSprinter" 37090
Here is the exploded view diagram
https://www.maerklin.de/service/...lnummer=37090&lang=1
It was released in 2000, has an FX decoder, no sound
The train was fitted with one motorized head and another unmotorized and a slider inversion system.
This works ONLY if both heads are connected together. The motorized head may work alone but ONLY forwards. As soon as you reverse it, it switches to the slider at the other end of the train AND - IF NOT CONNECTED - becomes dead.
Insert only the wagons specially fitted with current conducting couplers
Other possibilities are:
- a fried decoder because a blue Märklin transformer was used
- a current pick-up issue
- a dirty motor
More details on the model here
http:/https://www.maerkl...e/details/article/37090/
Offline rickjames84
#4 Posted : 14 December 2024 12:49:23(UTC)
rickjames84
Hi Rick
- a dirty motor
Thanks for the reply, didnt realize it was such an older set, I will do the test you recommend.
Offline rickjames84
#5 Posted : 14 December 2024 12:53:05(UTC)
rickjames84
Sorry for the sparse info
its the Marklin 37090 Cargo Sprinter, When I place it on the track there is spark or anything. It has a grinder on the bottom Im guessing 3 track. It worked fine for a lap and just stopped and havent worked since.
#6 Posted : 14 December 2024 14:36:22(UTC)
I gues Rick means decoder by "generator", and slider by grinder?
Offline rickjames84
#7 Posted : 14 December 2024 14:49:35(UTC)
rickjames84
Generatore, the motor that spins the wheels.
#8 Posted : 14 December 2024 14:50:37(UTC)
Grinder seems to be a fairly literal translation from the German for the slider. I have come across this translation many times in the past.
#9 Posted : 14 December 2024 14:52:28(UTC)
Deutshe' is "schlafer". Shoe or slider. If you order one from Marklin USA, it is a pick-up shoe.
Offline rickjames84
#10 Posted : 14 December 2024 17:10:39(UTC)
rickjames84
*UPDATE*
So I reconnect with the other locomotive I’m hearing a buzzing sound then it stops. No lights or movement. I think I may have a bad decoder. Since it’s outdated. I’m thinking of updating to a modern decoder. Any recommendations?
#11 Posted : 14 December 2024 20:38:19(UTC)
You have been a member since:: 28/11/2007(UTC)
What happens when you reverse direction? The set was designed to pick up power from the leading slider. See if the unit works again.
Can you tell where the buzzing is coming from? Does it sound like a motor trying to turn or does it sound like a short circuit?
Is it coming from the car with the motor or from the other end?
As far as changing the decoder, this was not a model with a PC board with a 8, 16 or 22pin plug-in decoder. You may have to find a solution that would include some kind of replacement for the board as well.
Offline rickjames84
#12 Posted : 14 December 2024 21:40:04(UTC)
rickjames84
I included a video
IMG_5557 3.mov (11,330kb) downloaded 54 time(s).
#13 Posted : 15 December 2024 23:52:22(UTC)
I think that the locomotive is having trouble going straight up... Your video needs to be rotated ;)
First thing to do is to remove the container (cover) for the motor. Then do what you did in the video again. Try to determine whether the buzzing is coming from the motor or from the body of the car, where the circuit board and decoder are located. It might also help to connect both cab units and test again.
Does it sound like the motor is trying to turn?
If that is the case, don't try to force it and power down.
This page was generated in 0.403 seconds.
