Offline Ace Wickwire
#1 Posted : 08 December 2024 02:54:02(UTC)
Ace Wickwire
I recently replaced the tires on my Marklin 3089 Red Baron BR 03-10 with new 7152's and they are really stretched tight on the wheel. Enough that at some places the rubber is very narrow. Didn't seem right, so tried some from a different package and same result. The expanded parts diagram I have for the loco show these to be the right tires. Did I get a bad batch of tires, did the size change from when this loco was made to present, something else to consider?
The loco was unable to get traction climbing an incline that my other locos have no problem with. It seems like it has plenty of power but just not enough grip.
Help is much appreciated.
thanks 1 user liked this useful post by Ace Wickwire
#2 Posted : 08 December 2024 14:48:48(UTC)
Maybe they shrank? Or try the next size up? Depending on the makr, sizes may not be to exact specs. Like clothing, and shoes are.
Offline TrainIride
#3 Posted : 08 December 2024 15:55:50(UTC)
TrainIride
I checked in all my catalogs, it is indeed the reference 7152 which is indicated.
I don't have this model, someone who has it here could confirm this.
Or there is a packaging error...
Best Regards
Joël
#4 Posted : 08 December 2024 16:57:26(UTC)
Most passenger steamers with 3 large driving axles take #7152, including my br10. I have #7152, 7153, and 7154. The other 3 are all smaller than #752
#5 Posted : 08 December 2024 17:50:42(UTC)
Installing the "Haftreifen" on Märklin wheels is a bit delicate but not so much on the 3089 PROVIDED you have removed the body and removed the screw that hold the coupling bar (Koppelstange).
Once you have done this:
- clean the grove (residues of the previous tire and oil)
- use RECENTLY-purchased traction tires 7152
- use a very thin screwdriver (one MM or less) to help the tire go UNIFORMLY into the grove
- the trick is to have the screwdriver parallel to the axle , above the grove and touching the wheel flange
- manage to have the tire go around the screwdriver and slide the screwdriver above the grove for more than a wheel turn
That way, the tire tension is uniform (and NOT streched at one point and almost overflowing the grove at another point).
Take more time to write it that to do it.
#6 Posted : 09 December 2024 00:52:06(UTC)
Ace Wickwire
Thanks all for the helpful and useful info.
thanks 2 users liked this useful post by Ace Wickwire
Offline bph
#7 Posted : 09 December 2024 14:53:24(UTC)
If you can't get the 7152 to work, you could try E656520, as they are slightly "bigger" than 7152.
I don't have the 3089, but I tested it quickly on a spare 3085 wheel that I have. The 3085 is listed with 7152, but E656520 seems to be a better fit on the 3085.
There might be other alternatives also. e.g. E656520 but I believe that one might be too loose on the wheels.
#8 Posted : 09 December 2024 15:50:39(UTC)
Ace Wickwire
Thanks for the suggestion of E656520 and seems like a larger size is what is needed. Will also give that a try.
Offline 1borna
#9 Posted : 16 December 2024 21:44:34(UTC)
1borna
Croatia
I think they've reduced the width of the tires in recent years/decades and the grooves on the wheels are narrower than before? In any case, the tire must be tight on the wheel because if it's loose it will fall off quickly!
thanks 1 user liked this useful post by 1borna
This page was generated in 0.398 seconds.
