Offline Roman
#1 Posted : 05 December 2024 06:17:18(UTC)
Roman
Hello all,
I have a SEH 800 that I don't have a wiring print for. If you might have a good photo of the chassis or book image to share, I'd appreciate it. It's a 3013.1 version with the two step direction change. I had a loose light wire and probably soldered it wrong. Now it only goes in one direction. Thank you.
Roman
Offline TrainIride
#2 Posted : 05 December 2024 10:39:58(UTC)
TrainIride
Long ago I had rewired a 3024 from 1959.
Well , it is not a SEH800 - 3013 ,
it's certainly not the same reversing unit,
but maybe it can help.
Marklin-3024-little-restoration
Best Regards
Joël
Offline Roman
#3 Posted : 05 December 2024 17:10:39(UTC)
Roman
Joël,
Thank you for your time and reply. Quite a detailed restoration.
Roman
thanks 1 user liked this useful post by Roman
#4 Posted : 06 December 2024 01:45:24(UTC)
Just one quick question... What happens when you manually reverse the direction using the switch on the side of the locomotive?
That model is one of the ones with a three position reverse unit... Forward - Neutral - Reverse. In the Neutral position, all lights should be on, but no motor.
This may provide some info:
https://www.marklin-user...s/t36079-RES-800-reverse
https://marklinstop.com/...-800-series-locomotives/
This page was generated in 0.251 seconds.
