Offline Kinhky
#1 Posted : 03 December 2024 04:13:00(UTC)
Kinhky
Viet Nam
Hello
I am new to the forum. I have a collection of H0 scale locomotive models from Roco and Trix (2-rail, DC and DCC+Sound). I run them on H0 layout (E-Z bachmann track), using Z21 controller, Bachmann for DC. I do not have any AC (3-rail) models from Marklin or other brands.
My friend recently gave me some AC (3-rail) models from Marklin, all diesel locomotives, H0 scale.
I have 2 options
1. Buy more Marklin tracks and controls to create a layout independent of the existing layout?
2. Convert the other Marklin locos to 2-rail to operate on the existing layout?
Which option do you think should I choose?
Offline dominator
#2 Posted : 03 December 2024 05:27:05(UTC)
dominator
I suspect it will far easier to buy Marklin 3 rail track and controllers to run those locos independently.
Northland. NZ
Offline Kinhky
#3 Posted : 03 December 2024 07:12:14(UTC)
Kinhky
Viet Nam
If I want to explore the technology, is it easy to replace?
If so, do I have to replace the motor or decoder or just replace the wheel and rewire the power supply to the motor?
#4 Posted : 03 December 2024 10:48:04(UTC)
No, it is not easy.
Depends on the Märklin model.
You probably need at least a lathe for converting the wheels.
Here is an example of a 3-rail to 2-rail conversion of an old H0 scale Märklin German class 81 three-axle steam locomotive - see two videos in German language:
Offline Kinhky
#5 Posted : 04 December 2024 03:21:58(UTC)
Kinhky
Viet Nam
Of course it is not easy to change from 3 rails to 2 rails.
For the wheels I think it is simple because now shops sell AC and DC wheels to install when needed.
Mainly the motor. If the motor uses AC input, then maybe we have to replace it completely or use a DC converter to take the power from the wheel to AC?
#6 Posted : 04 December 2024 08:16:14(UTC)
Old Märklin H0 locos have AC/DC motors.
Some folks use AC for analogue operation, some use DC for analogue operation.
Decoders always use DC to run those.
For better performance, replace the field coil with a permanent magnet.
This page was generated in 0.334 seconds.
