Offline Alex H
#1 Posted : 05 November 2024 16:23:14(UTC)
Alex H
I would welcome people's thoughts on track cleaning for Marklin C track. Does anyone use a cleaning wagon, and are they any good?
Many thanks
Alex
thanks 1 user liked this useful post by Alex H
#2 Posted : 05 November 2024 22:12:13(UTC)
I don't, but many do use a cleaning wagon. In the only area that is a stretch for me to reach, I rubber band a cloth to a stick and use karosene, then wipe off the excess with the dry side.
Offline dickinsonj
#3 Posted : 06 November 2024 00:44:56(UTC)
HI Alex,
I use the Marklin cleaning wagons and they work quite well. I find them perfect for both light cleaning and maintaining already cleaned track.
Offline Alex H
#4 Posted : 06 November 2024 09:04:30(UTC)
Alex H
HI Alex,
Can I ask which cleaning wagon you have. The only one that seems to be available at the moment is the 46049
Alex
Offline PeFu
#5 Posted : 06 November 2024 11:17:12(UTC)
PeFu
I recommend the following forum thread:
https://www.marklin-user...cience-of-track-cleaning
In the thread, there is a table ranking solvents for cleaning tracks. It’s not only about cleaning! The solvent can also limit the microsparks between wheels and tracks that causes ”blank gunk”. I’m very happy since introducing CRC Contact Cleaner for cleaning.
Smile
thanks 4 users liked this useful post by PeFu
Offline dickinsonj
#6 Posted : 06 November 2024 14:01:48(UTC)
The 46049 is what I use. Sometimes more aggressive cleaning is needed and the thread that PeFu listed is a great discussion about what to use and not to use when cleaning your track.
Offline ccranium
#7 Posted : 06 November 2024 14:32:30(UTC)
ccranium
Smile
I also recommend the CRC Contact Cleaner; it does a great job on tracks, wheels, axles and even lok motor servicing, with no residue once you remove the dissolved dirt etc. with cotton swabs or rags and elbow (finger?) grease. I spray some into the cap and dip the cotton swabs. It's harder for me to find in retail stores for the last year or so; I got some recently on Amazon and eBay. I get very little black gunk accumulation on wheels and tracks any more.
I haven't used the WD-40 Contact Cleaner but its product description says it's residue-free; I'm not a fan of WD-40's flip-up nozzles though. I find they wear out and cause lots of drips from the can.
I've never used kerosene for train cleaning; my recollection from other uses is it leaves a residue, which seems like a dirt magnet. It's flammability and VOC are also negatives for me.
Offline rhfil
#8 Posted : 06 November 2024 15:35:25(UTC)
rhfil
I bought felt furniture pads, cut them to slightly larger than the width of the rails and use alcohol as a solvent. The alcohol evaporates quickly. I am strongly opposed to using any material which scratches the surface of the rails as that creates scratches which collect dirt and cause sparking.
thanks 3 users liked this useful post by rhfil
#9 Posted : 06 November 2024 17:30:01(UTC)
Hi Alex
I have a Märklin track-cleaning wagon and I don't use it anymore:
- it does not clean the studs, the ONLY part that can rust
- wiping the rail with a felt does not remove the dirt on the track, unless you leave the cleaning car in operation all the time. You need a hard-pulling loco to pull a consist including this car.
What I use is a grade 2000 or grade 5000 abrasive paper (used to polish bodywork on cars with water. It removes all the dirt and the grain is so small that no groves are created in the rail or on the studs.
Contact issues are often caused by other things that need addressing:
- poor axle contact on locos (especially those with few axles). Cure: a tiny drop of oil (use an hypodermic seringe), let the loco run, clean the residue from the axle
- of course, wheels must be very clean (use a cotton swab with Isopropyl alcool
- sliders: worn, non-flat, surface metal treatment gone, dirty zone between the spring and the slider-shoe. All this calls for a slider replacement
- occasional vacum-cleaning of tracks helps a lot.
Offline Alex H
#10 Posted : 06 November 2024 20:57:38(UTC)
Alex H
Thanks everyone for your suggestions and recommendations.
Guest (6)
This page was generated in 0.522 seconds.
