Offline LionelMPC
#1 Posted : 06 November 2024 02:59:29(UTC)
LionelMPC
Hello All,
It's been several years since I've posted on here. I'm currently helping my father get his 1950s Marklin collection out and running. while building a layout with 3600 track to run the trains on. I have a few of the 800 series with the double click reverse (such as the 1956 FM 800 among others) that have reverse springs that are a little weak. I am assuming that the early Telex reverse units use the same spring. Are these springs still available and if so what is the part number? I have the standard 7194 reverse springs on hand and I have made them work by stretching them, but they are definitely shorter than the originals. I'd really like to get the correct springs if they are available.
Thanks!
James
thanks 1 user liked this useful post by LionelMPC
#2 Posted : 06 November 2024 06:06:07(UTC)
You can check with Ritter Restaurationen or Amiba.ch to see if they have any spares available.
#3 Posted : 06 November 2024 12:10:18(UTC)
Originally Posted by: LionelMPC Go to Quoted Post
Hello All,
Thanks!
James
I believe the 7194 is the correct spring. I have just been rejuvenating some old locos and 7194 is the spring I have used. If you use a longer spring I think you will find that the reverse unit will tend to pull the armature in when the transformer is at maximum speed.
Online JohnjeanB
#4 Posted : 07 November 2024 01:03:31(UTC)
What can I say more beyond all the valuable advice?
Märklin provides those under 2 different numbers 7194 (5 pieces) and E213730 (10 pieces)
https://www.maerklinshop.de/ersa...chaltschieberfeder-10-st
A good Märklinist cannot do without them as even when there are little differences they may help repair a pantograph or a M turnout or even C turnout (a bit streching is needed)
This page was generated in 0.372 seconds.
