#1 Posted : 12 October 2024 07:38:54(UTC)
I did visit Märklins homepage to read and find out MS2 todays correct version but did found two version that seems wrong.
The first it stand 3.121 by download manual of the MS2.
In other places it stand 3.55.
Here in the forum somebody said version 4.15 but i can only see this at MS2 WLAN (60667).
What is the correct version of today for the standard MS2 (60657)?
Offline torhb
#2 Posted : 12 October 2024 10:17:01(UTC)
torhb
MS2 firmware version 3.55 is mentioned "everywhere" because that is the first version supporting 32 functions on thr MS2.
Firmware version 3.121 is the newest. 121 is higher than 55, ergo it is a newer release.
Tor Harald Bøhler
Tor Harald Bøhler
Oppegård, Norway
thanks 1 user liked this useful post by torhb
Offline poulmh
#3 Posted : 12 October 2024 12:52:24(UTC)
poulmh
My MS2 has ver. 4.15
____________
Poul M Hansen
thanks 1 user liked this useful post by poulmh
#4 Posted : 12 October 2024 17:38:32(UTC)
What is the difference between 3.121 and 4.15?
Offline Bent
#5 Posted : 12 October 2024 18:22:03(UTC)
Bent
Hardware / software revision?
Bent
#6 Posted : 12 October 2024 20:25:02(UTC)
The update to 4.xx is required for use with the MS2-WLAN iirc.
#7 Posted : 13 October 2024 13:26:58(UTC)
Are we discuss in two different version?
MS2 version 3.121
MS2 WLAN version 4.15
Offline bph
#8 Posted : 13 October 2024 15:12:19(UTC)
MS2 version 3.121
my regular MS2 has software version 4.15
#9 Posted : 13 October 2024 15:28:07(UTC)
MS2 version 3.121
No, the ms2/Track box has a minimum software level to work with the ms2-WLAN and its interface box, and I believe that software is 4.15 for the standard ms2, and is only available from a cs3 that has been updated on the internet. There is no USB update for a cs2 or cs3 that has this ms2 software available.
Offline Bogenschütze
#10 Posted : 13 October 2024 17:07:32(UTC)
Bogenschütze
A fellow UK member of this forum with a CS3 (MU5TN4N6 - what a star!) kindly updated my wired MS2 (60657) recently. Before the update I was at v.3.55 and after I expected to see v.3.121. When I got it home, I noticed it had actually updated to v.4.15. I was initially concerned that this was an error as I understood that v.4.15 is the current SW version for the WLAN MS2. However, a quick check with the updated MS2 plugged in to my layout and everything worked just fine.
So, my two penny worth is that v.3.121 contains all the latest features for a non-WLAN MS2 but it does no harm to load v.4.15 as this contains everything in v.3.121 plus all the necessary extra features required by a WLAN MS2 (although the latter features would of course be superfluous).
Edited by user 03 November 2024 10:39:24(UTC)  | Reason: Not specified
Marklin - "The train set I never had as a child."
Keith Bowman
thanks 1 user liked this useful post by Bogenschütze
This page was generated in 0.389 seconds.
