Offline AjayTele
#1 Posted : 10 October 2024 06:24:06(UTC)
AjayTele
Hi everyone! I am looking at buying a used Marklin Loco that appears to have been converted from Analogue to Digital.
But I would like to use it on my analogue system.
What is involved in removing the digital conversion? Is that possible?
Reliving my childhood...
thanks 2 users liked this useful post by AjayTele
Offline PeFu
#2 Posted : 10 October 2024 07:32:16(UTC)
PeFu
Well, the digital converted loco could actually behave nicer on your analogue layout, than as an analogue loco! Smoother running, and even better if also the motor has been upgraded from 3 poles to 5 poles when converted. Smoother direction switch etc. However, there are a few heads-ups:
(1) If you have the ”blue” or even older transformers, the power from a direction switch event could damage the decoder.
(2) Analogue mode could have been disabled on the decoder. I do this myself on some locos to prevent them from running uncontrolled at short circuit events. Analogue mode can be enabled using a digital controller.
So, I wouldn’t hesitate trying the digital loco on an analogue layout! Smile
thanks 3 users liked this useful post by PeFu
Offline hennabm
#3 Posted : 10 October 2024 18:51:40(UTC)
hennabm
I did it on an old 3322. The only real change needed was to remove the decoder and fit a standard reverser unit.
I also took the opportunity to wire the lamps as directional.
So I would say it depends on the loco and what has been done to modify it for digital.
1957 - 1985 era
What's digital?
thanks 2 users liked this useful post by hennabm
Offline BenP
#4 Posted : 11 October 2024 16:46:18(UTC)
BenP
Why analogize, I wondered. Then I read your signature 😄
Ben
Ben van der Pluijm--
This page was generated in 0.358 seconds.
