Offline twmarklinfan
#1 Posted : 29 September 2024 18:48:55(UTC)
twmarklinfan
43660
After quite a long time I got the above coach and it’s sisters out of their boxes and on the layout ready for the arrival of my BR 218in the ICE livery. Not sure when it will arrive though!
Now with everything connected up and registered on my CS3 I turn the lights on. All of the coaches have grey interiors except the 43660 which is a cream colour. Should this be cream or should it be grey? Could someone else have a look at theirs, please?
If it should be grey does anyone know what shade of grey Markin uses?n
The problem with the cream is that with the lights on the interior is very bright compared to the other coaches.
Many thanks
thanks 1 user liked this useful post by twmarklinfan
#2 Posted : 30 September 2024 13:57:14(UTC)
It's a second class coach. I have the cab control coach and a second class coach in the newer length to match yours. Both interiors are cream. I have the older shorter start up series and the second class coach is blue inside. The older first class coach is dark gray inside.
#3 Posted : 30 September 2024 20:55:32(UTC)
I did not know that Marklin produced the interior of coaches as the original. From what I see it is cheap plastic of whatever colour they have at that time. I repaint the inside with some detail ie the floor is not the same colur as the seats etc. I had an ESU coach which was slightly better regarding the interior but the high cost is not worth buying.
#4 Posted : 01 October 2024 01:17:55(UTC)
The DB rolling stock photo database is a good source. Just search for the coach classification and type and Google tells the search result.
#5 Posted : 01 October 2024 01:44:29(UTC)
This is a former Avmz207 1st class (Eurofima) coach which has been converted and now runs as a 2nd class coach in IC consists. From what I have been able to learn, the Bvmkz 856 are former coaches from the DBAG DB Touristik Tourist Train. (See Maerklin 43878/879).
The interior may have different colors than the regular DBAG IC stock coaches.
http://www.railfaneurope...61_80_84-90_912-5_K1.jpg
http://www.railfaneurope...tikzug/Bvmkz856_HHML.jpg
Interior:
http://www.railfaneurope...g/touristenzug2000_3.jpg
Here is the interior of a Avmz108 (upgraded Avmz207) but still first class (two versions):
http://www.railfaneurope...61_80_19-91_114-7_i1.jpg
http://www.railfaneurope...07-108-106/110226-35.jpg
#6 Posted : 01 October 2024 03:27:27(UTC)
twmarklinfan
Thanks very much everybody. I have another Marklin IC coach on its way so I will be interested to see what colours that has. In the meantime out with the paint brushes!
This page was generated in 0.317 seconds.
