Offline Drongo
#1 Posted : 04 September 2024 09:18:01(UTC)
Drongo
This loco suddenly stopped going in reverse direction - everything else is working.
Anyone have any ideas ?
Greg
Offline Paul59
#2 Posted : 04 September 2024 09:47:39(UTC)
Paul59
Assuming the loco is a traditional analogue one then check the wires from the reverser to the field magnet. There are two wires, one for each direction.
A couple of times I have had a loco stop running in one direction and both times it has been one of these wires either broken or detached.
This is especially likely if the loco is a bogie one such as a diesel or electric since the wires are flexed as the motor bogie moves. Moreso if the wires are a bit short or not routed in a way that allows them to move freely.
If it is a digital loco then I'll leave it to somebody else to advise as I gave up on digital a long while ago.
Good luck Greg.
Paul
Offline mvd71
#3 Posted : 04 September 2024 09:59:36(UTC)
Hi Greg,
Try resetting the decoder, that may fix it (long shot) otherwise I would suspect a faulty decoder.
Cheers….
#4 Posted : 04 September 2024 13:20:07(UTC)
Delete
Offline rhfil
#5 Posted : 04 September 2024 13:50:18(UTC)
rhfil
It has a mfx+ decoder so if you have a CS controller, not sure about the MS, you can do a factory reset. You can also check the decoder and confirm that it has the proper cv for reverse.
#6 Posted : 04 September 2024 15:00:52(UTC)
A tip...check if there is contact between motor and the PCP by pull off mfx decoder and use multimeter to see if there is contact.
Offline Drongo
#7 Posted : 12 September 2024 14:55:07(UTC)
Drongo
Thanks everyone for your thoughts.
I had a friend over who ran a few tests using the ESU Lokprogrammer and decoder tester and concluded that it was the decoder causing the problem. Everything else works and to replace the decoder is about A$150 which is too expensive just to have the loco go in reverse. So, I will have a loco that can only go forward which is all I really need.
Greg
This page was generated in 0.273 seconds.
