#1 Posted : 01 September 2024 09:48:01(UTC)
Did bought MIBA 9/2024 and there was a test about Pikos new Vectron BR249.
One of the pictures show drive shafts made of plastic.
Is all of the Pikos locomotives models with plastic drive shafts??
#2 Posted : 01 September 2024 11:08:01(UTC)
Yes, same with Marklin and Roco since cardan shaft drive type with center motor.
#3 Posted : 01 September 2024 12:41:39(UTC)
You did missunderstand me. I wonder about metal axles as drive shaft.
#4 Posted : 01 September 2024 14:33:05(UTC)
Axles are axles Goofy. The gears are nylon, the axles are always metal. The worm gear is brass, the gear train axles metal. Some older Trix, etc. used brass gears.
#5 Posted : 01 September 2024 17:41:20(UTC)
Carden drives are plastic. Axles are metal. Maybe I dont understand the question as to what part of the loco we are looking at.
#6 Posted : 03 September 2024 20:39:04(UTC)
Dont know if Goofy is coming back to this. I feel that where a post is started the poster should let us know if the problem has been solved etc. Anyway hope Goofy is OK.
#7 Posted : 06 September 2024 08:21:55(UTC)
Many Märklin Hobby locos have plastic axles nowadays. This allows the same wheelsets to be used for Märklin and Trix.
I haven't seen plastic axles in Piko locos yet.
This page was generated in 0.354 seconds.
