Offline andrea_spv
#1 Posted : 02 August 2024 10:40:02(UTC)
andrea_spv
hello to all.
I bought a new decoder esu lokpilot 5 - item 59610.
I have a Cs3 in my layout with last firmware uploaded.
I try to put my loco in programming track to add a new locomotive with this ESU 59610.
I add a new loco DCC, close the mask. Then I edited my last loco added and try to set a new address to locomotive for cv1 (after use read loco).
I can't change loco address and the locomotive doesn't move.
It seems that the new decoder is not recognized and does not work and it is not possible to change addresses or anything else.. on the control unit CS3, no error appears.
where am I wrong? can someone help me? thanks
locomotive is a native ROCO AC item 69890.
#2 Posted : 02 August 2024 10:43:50(UTC)
Welcome to the forum.
The decoder ignores DCC and MM if mfx is enabled in the decoder and in the controller.
Check if the decoder registered using mfx. Name should be similar to "ESU Lokpilot".
Offline andrea_spv
#3 Posted : 02 August 2024 10:46:22(UTC)
andrea_spv
thank you very much for you reply.
How I can check this by CS3... my decoder is new, first use off the box. I just plugged in the locomotive.
Offline rhfil
#4 Posted : 02 August 2024 15:18:06(UTC)
rhfil
It should have automatically registered. Pull up the loco edit screen and it most likely is the first one in the list, top left. Or you can do a search for ESU.
Offline andrea_spv
#5 Posted : 02 August 2024 16:13:26(UTC)
andrea_spv
I bought the 59610 ESU, thinking it was MFX, so as to have the best on Marklin for the CS3. But I see that the new MFX locomotives are not always immediately detected by the central.. sometimes yes and sometimes no. Normally, after how long does the new locomotive come out on the track if MFX?
Offline rhfil
#6 Posted : 02 August 2024 19:34:05(UTC)
rhfil
According to the ESU website the 59610 is dcc. I have no idea how to program a esu decoder. I think I read that you need to contact the ESU website with a pc. Sorry. Are there instructions with the 59610?
Offline andrea_spv
#7 Posted : 02 August 2024 19:36:31(UTC)
andrea_spv
hi i have other esu decoders, both mfx and older without mfx but for AC. Simple, you create a new loco with the "+" button and choose DCC. You put it on the programming track, close the card and reopen it and read the decoder and it tells you what address the loco has in CV1 that you can change from the cs3 screen.
#8 Posted : 03 August 2024 12:44:21(UTC)
Did you put the loco on the programming track first before you did start read up the decoder?
Offline EMD_645
#9 Posted : 03 August 2024 14:42:56(UTC)
EMD_645
Ciao Andrea,
To help you with this we need answers to some questions.
1. If you check your loco-list. Is there a MFX-loco called something where the name contains ESU or maybe a DCC-loco with the name DCC-3 that has been identified?
2. If you enter the "add loco" menu int the CS3, put the loco with the ESU decoder on the programming-track with the CS3 in "STOP"-mode. Then deactivate "STOP".
Does the CS3 start to add the loco within 10 seconds? With this I mean that the MFX symbol should start flashing.
There can sometimes be problems with Märklin control-units like the CS3 and MS3 and multiprotocol decoders like the 59610. The control-units favor the MFX protocol and if you want to run something else you have to deactivate MFX with bit-CVs or the Lokprogrammer.
Ti scrivo anche in italiano... È più facile. ;)
Per aiutarti con questo, abbiamo bisogno di risposte a alcune domande.
1. Se controlli la tua lista delle locomotive, c'è una loco MFX chiamata qualcosa il cui nome contiene ESU o forse una loco DCC con il nome DCC-3 che è stata identificata?
2. Se entri nel menu "aggiungi loco" nel CS3, metti la loco con il decoder ESU sul binario di programmazione con il CS3 in modalità "STOP". Poi disattiva "STOP".
Il CS3 inizia ad aggiungere la loco entro 10 secondi? Con questo intendo che il simbolo MFX dovrebbe iniziare a lampeggiare.
A volte ci possono essere problemi con le unità di controllo Märklin come il CS3 e MS3 e i decoder multiprotocollo come il 59610. Le unità di controllo favoriscono il protocollo MFX e se vuoi utilizzare qualcos'altro devi disattivare MFX con bit-CV o il Lokprogrammer.
Offline andrea_spv
#10 Posted : 04 August 2024 08:45:17(UTC)
andrea_spv
Originally Posted by: EMD_645 Go to Quoted Post
Ciao Andrea,
thanks for your reply. I will do some more tests. On my layout there are about 25 locomotives. At least 10 are not marklin and have esu 5 and esu 5 loksound decoders. Normally they go without problems together with marklin locomotives that are always perfect. But we have few Italian machines and therefore some people from my country, also buy Italian Rivarossi and Roco CC locomotives and we convert them to AC system. However, this one that I want to use is a Roco AC E444 native for marklin AC system. The old decoder is perhaps an Esu or some tell me old Lenz. I had this new Esu 5 decoder at home and I thought it was easy as always to use it. Only strangely from the programming track I do not see reactions after programming. I had problems on the Roco code 69890 with its original decoder and I decided to try this new decoder that I have at home. The original decoder works, but I "CANNOT" change the address of the locomotive.. strange thing.
Is there a menu on the CS3 to read the decoder model? (speaking in general) ?
Offline EMD_645
#11 Posted : 04 August 2024 09:40:54(UTC)
EMD_645
Ciao Andrea,
Sounds very strange. But in the world of digital decoders, nothing surprises me anymore. They are quite delicate pieces of electronics that can behave in the most curious of ways.
There is a menu for decoder configuration in the CS3. One thing you have to consider is that the loco has to be added to the locomotive list in the CS3 in order to be modified. If it´s DCC you have to know the adress it already has or read the loco with the "read" function in the CS3. Also, check that your loco has not registered as an MFX loco on it´s own and sits in the locomotive list already.
It´s also important that the loco is connected to the programming track and not the main track.
Check the video below on how to edit the various formats with the CS3.
thanks 1 user liked this useful post by EMD_645
Offline andrea_spv
#12 Posted : 04 August 2024 10:42:16(UTC)
andrea_spv
Ciao Andrea,
All correct. I know this menu.
as you write, anything goes, unfortunately. Marklin is great, but since the Cs3 is a super central and multi-protocol, it should do something a little more even for "non" Marklin decoders.
Anyway, the strange thing with this new decoder is that when I change the address of the locomotive, therefore acting on the CV1 of the decoder via Cs3, I have no errors, but both with base address 3 and with others, I have no reading or writing errors, but after setting, the locomotive does not move. Ditto with the decoder mounted by factory on the Roco AC E444 code 69890. With the old factory decoder, it only works if I leave the factory base address "3".. if I change and put the "19", for me available free, it writes it, but then the locomotive does not go anymore, until I insert the address "3" again.
Offline ktsolias
#13 Posted : 04 August 2024 11:37:52(UTC)
ktsolias
The ESU 59610 is an M4 capable decoder
So it will be recognized automatically on CS3
Is very complicated to change the address on an mfx decoder
Costas
Offline andrea_spv
#14 Posted : 04 August 2024 15:14:06(UTC)
andrea_spv
Costas
if it was recognized automatically and the locomotive received the address automatically as for the mfx decoders, I would be more than happy.. My problem is that it doesn't work and is not recognized, that's why I asked for help..
Offline EMD_645
#15 Posted : 04 August 2024 15:49:59(UTC)
EMD_645
Costas
I understand that you are puzzled. This is very strange. I am very familiar with ESU and their ecosystem and this is the first time I´ve heard of someone not being able to change the address.
Do you have access to a Lokprogrammer? If you don´t have one yourself then maybe a friend or a nearby shop has one? It will most certainly help you program the decoder.
If you use ESU decoders often it´s a worthwhile investment to make. I use mine all the time.
Have you updated your CS3 recently? I know of some people that are running software version 2.5.1 that have had problems with ESU and Zimo decoders.
The software version 2.5.2 was released to remedy this.
I see that you are in Milano. If you are willing to make the trip, you could try and take your locomotive to the lovely people at Artuffo Modellismo in Torino.
They are Märklin specialists and probably have both the knowledge and equipment to help you.
https://artuffo.com/
Offline andrea_spv
#16 Posted : 04 August 2024 16:25:50(UTC)
andrea_spv
thanks, yes I'm near milan. Now the shops are almost all closed... August in Italy is like this, summer vacation period. After August 25th I will go to the shop to have the new decoder checked, maybe it's broken. The other ones I have from ESU, all work.
I had the lokprogrammer, sold years ago. For 22 years I collected DC models, then sold everything and stopped for 3 years. Then I discovered Marklin which always works really well.
My idea is that I had bad luck and probably the decoder is broken. The other ESU I use all work.
The control unit is updated to the latest firmware.
thanks 1 user liked this useful post by andrea_spv
Offline EMD_645
#17 Posted : 04 August 2024 18:44:13(UTC)
EMD_645
Ok, good luck. Keep us posted on how everything goes. Smile
And BTW, I saw that Artuffo has a super-sale on Märklin. And seem to be open even though August is a holiday-month. So maybe it’s worth the trip anyways?Hehe! BigGrin Razz
Online kiwiAlan
#18 Posted : 04 August 2024 23:34:17(UTC)
Since Covid happened ESU has had some problems with new decoders dying due to a substandard voltage regulator that they have been supplied. It seems that due to the component shortages some shortcuts were being taken by one of ESUs component suppliers. ESU have been replacing such decoders under warranty.
#19 Posted : 05 August 2024 10:10:11(UTC)
I do use ESU function decoder and these support also M4. I did install decoder to control the lightings in the wagons. No problem by registred decoder and after that i did configurated decoder too.
Offline mario54i
#20 Posted : 05 August 2024 10:59:57(UTC)
mario54i
Is it a Loksound FX decoder ? Regular Lokpilot FX shouldn't support M4.
thanks 2 users liked this useful post by mario54i
#21 Posted : 05 August 2024 16:30:07(UTC)
My mistake… i mean Lokpilot 5! It was 8 pol. Schnittstelle.
Soon later i did changed to lokpilot 5 Fx with only DCC to use and it works better in this way.
Offline EMD_645
#22 Posted : 21 September 2024 18:07:41(UTC)
EMD_645
Hi Andrea,
Have you been able to work out what the problem with your decoder was? I´m curious! Smile
This page was generated in 1.017 seconds.
