Offline Mille
#1 Posted : 26 July 2024 09:22:49(UTC)
Mille
Is it possible to use signal 74391 with Märklin
breakmodule if i vit of the plug?
thanks 1 user liked this useful post by Mille
#2 Posted : 26 July 2024 11:26:54(UTC)
Bonjour Mille
Anything is possible with some work and design changes.
The 74391 is a start-up signal meaning it is a set of LEDs with resistors and a cable / connector to plug to a signal control box 72751 or an M84
The breakmodule 72442 is a relay with some circuitry (diodes) to provide a slowing-down zone.
The breakmodule must be controlled by a digital decoder or by a switch controller
The breakmodule has a spare SPDT marked as signal to drive a luminous signal such as the 74391 but you must to a few things to connect
Here is an example of a breakmodule use
Making the adaptation of the 74391 signal to the breakmodule
- from the signal must come 3 wires to connect to a powered SPDT (like an M84 decoder)
- find a veroboard (or equivalent)of the appropriate thickness to cut and plug into the connector and wire to the spare SPDT of the breakmodule installing in series a resistor (1 kOhm and a DC power source (+5 or +12VDC)
Sorry for not being more precise as I never did it myself, so a bit of testing is in order
Offline Mille
#3 Posted : 26 July 2024 11:57:49(UTC)
Mille
Thanks John for your answer
Seems to be more difficult than i thought
This page was generated in 0.240 seconds.
