Offline obb_taurus
#1 Posted : 04 July 2024 17:41:01(UTC)
obb_taurus
Hi All,
I just replaced my old Ecos with a CS3 and have been familiarizing myself with the CS3. One thing I ran into while trying to setup turnouts is that my 3 way turnouts are not switching correctly, when I switch it to the right it goes left and vice versa, there is no problem with center. I'm using the Viessmann 5235 decoder in my 3 ways, I've been going through the CS3 to see if there's a way to change this behavior but haven't found anything, hoping someone can point me in the right direction to get this resolved.
Offline rhfil
#2 Posted : 05 July 2024 09:33:08(UTC)
rhfil
I seem to remember the same thing happening to me with a Marklin three way switch and can't remember how exactly I solved it but it was either reversing the wires to the switch or exchanging the assigned decoder addresses. It was simple though.
#3 Posted : 05 July 2024 11:10:52(UTC)
Hi Mike
The first thing coming to mind is to swap the switch connections between right and left. Not sure if the cable length allows it and I seem to remember it is not needed.
I have one of those decoder (way back before Märklin developped its own in-situ decoder) and it works perfectly well with a CS2 and since a few years with a CS3.
For Märklin CS3 , the 2 digital addresses must be consecutive and the left switch is the first address while the right one is the following one.
Sorry I can't help more
This page was generated in 0.325 seconds.
