Offline MALAVIKA
#1 Posted : 24 June 2024 14:27:35(UTC)
MALAVIKA
India
I am Kumar from India,
I have been getting a lot of help from forum members as I am trying to put my vintage layout 1955- 1970 back on track.
The CM Locomotive I used mainly to test track, signals etc. Now the lights work and the loco does move, but not smoothly. Without power the wheels cannot be rotated smoothly and some times not at all.
I have tried to lubricate the geared wheels and crank with singer seweing machine oil and that loosens the wheels and crank for some time but after some time it gets jammed again. Would you recommend I open the engine and clean everything with Alcohol spirit 99%.
Please help. Kumar
Offline analogmike
#2 Posted : 24 June 2024 22:14:22(UTC)
analogmike
Never try to turn the wheels manually. The wheels can slip on the axles causing them to be loose.
Sounds like you should disassemble the motor and clean everything with alcohol or lighter fluid then lightly oil on reassembly.
Youtube has lots of vids on the subject.
?si=TqSudyMnZPZiHov_
Good luck,
Mikey
Offline MALAVIKA
#3 Posted : 25 June 2024 08:18:46(UTC)
MALAVIKA
India
Hi Mike,
Thanks for the very helpful video. will do as suggested.
Kumar India
thanks 1 user liked this useful post by MALAVIKA
Offline analogmike
#4 Posted : 25 June 2024 14:18:17(UTC)
analogmike
Originally Posted by: MALAVIKA Go to Quoted Post
Hi Mike,
Kumar India
Let us know how you made out.
This page was generated in 0.241 seconds.
