Offline fabstar68
#1 Posted : 12 June 2024 19:27:49(UTC)
fabstar68
hi all,
i'm about to get my firs piko locomotive, which has a #56405 PIKO SmartDecoder 4.1 Sound PluX22 decoder. amongst the many functions, i was interested in the possibility of a constant braking distance. i read that this can be activated by ABC braking , DC braking (marklin braking module), speed set to zero, and DCC braking signal. i was interested in this last one, but i don't understand if this is something that can be sent with a marklin central station 3 (which i am about to get in place of my actual mobiles station 2), and/or this mode is only available with some pc programs and/or other ways which i don't know. thanks to those willing to give me a hand,
Fab
Online rhfil
#2 Posted : 13 June 2024 03:33:14(UTC)
rhfil
Not sure if I can provide you with the information you need. I do not have a Marklin braking module but a friend does and this is what he has found. The distance a train travels after activating the braking feature is dependent on the speed of the loco when it activates and the setting of the brake delay. I am not sure how "constant" you need but with experimenting he can get a loco to stop just short of the emergency stop feature.
#3 Posted : 13 June 2024 11:21:44(UTC)
Originally Posted by: fabstar68 Go to Quoted Post
hi all,
Fab
Hi Fab
I started purchasing a couple of Märklin brake modules but soon realized for a medium-size layout, there is a lot of wiring (3 sections with Märklin), it is not cheap and to handle bi-directional blocks is a pain in the neck.
Then I made my own brake module (using a relay to switch a DC voltage and a car 5W lamp in series to avoid destruction if a loco connects by accident the digital power and the DC power.
Last I used Rocrail (excellent, inexpensive software to manage trains) and using my all-purpose laptop and it gives me this:
- cost 5€ for a CAT5 cable between my CS3 and the laptop plus the facultative contribution to Rocrail
- reduced wiring: no more insulated track section, only track detection zones
- ANY trail can become a shuttle train and still stop at the right place
- any block can be bi-directional without ANY complication
- access to "Fish-bowl" operation (trains travel randomly anywhere permitted)
- access to 'Schedule Operation" (trains travel after a schedule on fixed or relative time)
- manual mode
- all signals are ONLY DECORATIVE so you may start with NO SIGNALS and then install nice signals ONLY where they are visible.
- start with Rocrail is progressive: when starting no checks on block lengths, train lengths, train constrains (electrified section, main line section, remote trunk line, etc), interdictions (goods trains, shuttle trains, etc) and all this can be added WHEN YOU WISH.
Your question "constant braking distance"
- fast trains travel ...fast and brake quickly while goods trains travel slow and brake/ start slowly.
- blocks have often a very variable length and some blocks are bi-directinal
So all this seems like mission impossible but it is not. Here is my solution:
- using Rocrail, each loco has four standard speed set individually: V_min, V_moy, V_route, V_max
- of course freight locos travel much slower than D-trains and a little slower than rail cars (Schinenbüsse)
- a loco speed between blocks is V_route, when it enter a block the V_moy is used and when coming near a red signal, thespeed is zero
- the adjustments on each loco are: maximum speed (resulting in a realistic route speed for that loco) and the inertia (acceleration and braking, set depending on the loco type
- I have standardized a length of deceleration of trains to 18 cm (to go from V_moy to zero and stop a few centimleters before the signal.
- no matter each loco speed and deceleration adjustment, the locos can be set to stop within 1 to 2 cm of the set location
- this is made possible because the slowing down zone of an approching train (variable length because all blocks have not the same length) must slow down from V_route to V_moy and must have finished the deceleration before entering the stop zone
To give an idea of the operations permitted by Rocrail ( or other more expensive train-control software) here is my layout in total automatic mode
Don't get the idea that controlling trains is gone. Quite the opposite, instead of being a loco driver you are a chief dispatcher
Offline fabstar68
#4 Posted : 13 June 2024 11:50:05(UTC)
fabstar68
thanks for the time you took for the reply, it's appreciated.
i will have a look at what you say, but regardless, i wanted to know more about this piko decoder functions, and what is this native DCC brake signals. i was planning to get to PC control software later in the year, i already have a lot to take in regarding the digital word, that is why i am delaying the PC software as long as possible, so i have time, in the meanwhile, to learn the basic aspects.
#5 Posted : 13 June 2024 12:10:41(UTC)
You say you are getting a CS3 which is a good move and I would wait until you have this and see the advanages over the mobile staion. I would not consider any software which can cause problems setting it up but rather play with the CS3 first.
Our hobby is about driving trains in my view and although I do have events in the CS3 I prefer to control the locos myself rather that just press a button and watch.
It is a matter of choice to have a computer controlled layout or you are the driver. A mixture can give the best of both worlds.
#6 Posted : 13 June 2024 13:45:33(UTC)
Hi Fab
I understand regarding the fixed braking distance by Piko decoders. This might work well but later force you to use Piko decoders on all locos which could be an inconvenience.
Also, this approach is dealing with two "speeds": route speed and zero speed. With rocrail the stop is reached in at leat 2 speed changes (and more if you like): route speed, station speed, zero speed.
Note: of course speed control with Rocrail is not limited to the 4 speeds I mentionned earlier. You may specify speeds in percentage of the maximum speed (defines on the decoder) and this can be block-dependent, itinerary-dependent and also influenced by the presence of switches (turnouts)
Regarding deferring the implementation of a train management software, David's advice makes perfect sense BUT, the problems with this approach are:
- additional wiring for stop and brake sections that are totally useless using Rocrail,
- location of the various detection zones are different.
Wiring is not my favourite, crawling under the table, drilling holes, etc.BigGrin
With a CS3 and using stop / brake sections, usually there is one detection covering the whole of the block and the occupancy feature on the CS3 used to create EVENTS.
With Rocrail you may have one, two or three detections zones depending on the stop precision needed and the mono directional or bi-directional features of the block.
So why start a complete wiring to change it later (6 months time?)
#7 Posted : 13 June 2024 15:51:05(UTC)
hi all,
Fab
It depends how you set dec. and what maximal speed set too.
CV4 are for the dec.
CV5 are to set maximal speed.
If you have 1 metres brake section you just set value in both CV4 and CV5.
If you want longer brake secition for example 2 metres then in case you have set higher value in both CV adress.
I don´t like Pikos decoder and i prefer to use ESU and Zimo decoder with ABC brake.
ABC brake are cheaper too than use Märklins expensive brake module.
Edited by user 14 June 2024 08:16:19(UTC)  | Reason: correct number CV5
Offline fabstar68
#8 Posted : 14 June 2024 10:31:45(UTC)
fabstar68
thank you all for your posts and clarification, they were extremly useful.
@John i have only built the "first floor" of the layout i have in mind , there are more to come. So i am in a position where, for some time, i will not have to build other tracks, i need time, and money, to finalize the first floor. that is why i can wait, experiment, and then finalize a solution and build the rest in the same fashion.
i have begun reading the documentation on Rocrail anyway. i just need to understand better where to position the detection zones. is there some document / link / tutorial / video , that explains in detail the strategy to project the position of detection zones in rocrail ?
thanks again
Fab
#9 Posted : 14 June 2024 14:59:20(UTC)
Hi Fab
I learned the hard way that changing detection zones on lower levels of track is very painful and the quality of work is inferior so I think, now that you are at the lower level, it is time to install the detection zones before covering the tracks with upper levels (I have 3 levels of tracks total). Testing your work is an absolute must.
First is a Rocrail page (here in English but you may get the same in Italian by replacing "en" with "it" at the end of the pathname.
Sensors and blocks with Rocrail - WIKI Page
Here are a few tips (If I may) when using Märklin C Track:
- you must select your priority: EITHER precision of stopping and security--> you need 2 sensors per mon-direction blocks and 3 sensors for bi-directional ones OR you select to minimize the number of sensors, then you may use one senor per block mono-directional or bi-directional BUT this is detrimental to the precision of stopping (you need blocks that are roughly twice the length of a train and also detrimental to the security because less zones will be under supervision. This choice is also reflected by a different deceleration adjustment on locos
- in each block, standardize the length of the IN detection: I use 20 to 22 cm. This allows any loco to go from V_moy to V0 (stop). That way you adjust all you locos on ONE block and this is good for all others.
- if you choose a one sensor per block approach then remember that only the central section is detected (otherwise train will stop far away from the signal and possibly not clearing the previous turnouts.
- C track turnouts may be tricky to insulate (for occupancy detection) so you may skip that part without jeopardizing the operation safety.
- using Märklin C Track insulators is fine BUT (1) make sure of the condition of the 74030 red isulator and (2) make sure that the facing rails over the insulator are not touching each other (a 0.5 mm clearance is recommended). Remember that when aging C-Track plastic retracts while the rails do not, resulting in phantom contacts.
- mark the rails where the insulation is made (I use a small bar of acrylic color and where the screws are used. Use a small number of them because when intervening for repairs on lower levels, accessibility is very poor (use a small mirror and a light).
- another method is to cut one of the rails using a hand drill (Proxxon / Dremel) and a diamond disk. Works very fine, can be reverted later BUT the rail must be thouroughly cleaned of stainless steel dust (Phantom contacts)
- always leave a little loop of connecting cable so that you may work on it later (remember turnouts will fail over the years
- avoid ABSOLUTELY using C-Track contact tracks like the 24994 as they are expensive, not very reliable and stop trains at slow speed (slider tacks off)
Offline fabstar68
#10 Posted : 16 June 2024 16:47:44(UTC)
fabstar68
thanks again John,
if you are so kind to continue giving me your expertise on the subject, here in attacchment is my current layer 1. Sx are signals, Tx are turnouts, FSxx are detection tracks. it is right circulation, german style.
the interrupted tracks on the lower right go on underneath in a shadow station, whilst the upper interrupted tracks are raised and continue to go down around the edges and raising to upper levels. Down center is the main station, middle center is the yard zone. there is also a ring between yard and external main lines, for a regional DB loop.
I have read the section about Rocrail sensor strategy, i think that i could use 3 sensors per block, maybe 4 on the main station blocks.
would you be so kind to share your layout, at least a piece of it similar to mine, with your signals position and detections zones, and give me an opinion on my actual detection zones strategy, which i have originally planned for usage with the CS3+ events functions & macros.
my sensation is that i have to change the last track of the detection zone of each block, which is a 236 mm straight, because otherwise the train would stop too soon. maybe i could swap it with a 64+172 (64 last), so that the train would stop a few cm before the signal. other hints ?
thx.
Edited by user 17 June 2024 12:26:54(UTC)  | Reason: Not specified
#11 Posted : 17 June 2024 13:20:21(UTC)
Hi Fab
I have not such a plan. Here is my layout plan basically on 3 levels
The lower level & shadow stations
The two upper levels
The lower level and grey zone of middle level handles long trains (1.6 m) while the rose part of the upper level, handles short trains (branch line trains and bus trains (Schienenbusses)
The arrows on tracks show you if the track is one way or double way track.
The rules are the same for one way tracks: 22 cm for the IN section and the rest (until the switches) is for the ENTER section
Bidirectional blocks
- short trains: a 22 cm section for ENTER and the rest (22 cm) for the IN section. The same sections become respectively IN and ENTER
- long trains: 22 cm section for ENTER, 22 cm for the IN section (at the other extremity of the block and in the middle the section is connected to ENTERSHORTIN
One very long block, in the shadow station center left in a staging block with 7 sections. It can host up to 7 locomotives. The sections of equal length (my choice) are "used by trains depending of their length and a small security spacing is calculated by Rocrail. It works flawlessly but requires a good understanding of staging blocks (not rocket science but open air testing is advised.
Offline fabstar68
#12 Posted : 17 June 2024 14:12:55(UTC)
fabstar68
thanks, that's a lot to study. i'm not sure how to recognize the sections, though. could you just take one example section and explain in details what are the tracks that are connected to the detection wire, what is its role (in, etc.), where is the signal in that section, are there other tracksi in the section that are part of the detection zone (meaning that their detection rail connection has been severed, too) and finally where are the insulators ? i think i got the idea, i just need to make sure i am not messing up something and discover it too late
This page was generated in 0.806 seconds.
