Offline maxgand
#1 Posted : 28 May 2024 13:04:44(UTC)
maxgand
Buongiorno ho registrato 4 deviatoi su CS3 60226 con M83 SC 1 SC 2 SC 3 Sc4, fino qui ok, quando clicco configurazione apparati nella finestra in basso mi compare indirizzo nome tempo commutazione in nero ma nella finestra indirizzo il MM non è evidenziato in nero ben definito, quando colloco apparati (deviatoi) sullo schema binari gli elementi li posiziono correttamente ma il loro nome è numero non compare?
Mi potete indicare la soluzione?
Grazie
/* For the rest of us - translation courtesy of Herr Google */
Hello I recorded 4 deviations on CS3 60226 with M83 SC 1 SC 2 SC 3 Sc4, so far ok, when I click configuration I use in the window at the bottom I appear address name time switching in black but in the address window the MM is not highlighted in well-defined black, when colloco mepparati (deviatoi) on the binary diagram the elements correctly place them but their name is not a number?
Can you tell me the solution?
Thank you
Edited by moderator 01 June 2024 01:27:49(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by maxgand
#2 Posted : 28 May 2024 14:21:32(UTC)
Anglaizie please. Most of us are best at english. I think the M83 has Italian instructions also.
Offline gamolina
#3 Posted : 01 June 2024 00:59:44(UTC)
gamolina
Argentina
Ciao, come hai configurato l'M83?
Prima leggi l'M83 con il CS3 e poi assegna gli interruttori
Saluti Guglielmo
/* For the rest of us */
How did you set up the M83?
First read the M83 with the CS3 and then assign the switches
Greetings William
thanks 1 user liked this useful post by gamolina
#4 Posted : 01 June 2024 13:02:17(UTC)
Ci, yes by clicking on the turnout you want to assign to the M83 port terminal and dragging it there.
This page was generated in 0.345 seconds.
