Joined: 13/01/2020(UTC) Posts: 9 Location: Liguria Genoa
Buongiorno ho registrato 4 deviatoi su CS3 60226 con M83 SC 1 SC 2 SC 3 Sc4, fino qui ok, quando clicco configurazione apparati nella finestra in basso mi compare indirizzo nome tempo commutazione in nero ma nella finestra indirizzo il MM non è evidenziato in nero ben definito, quando colloco apparati (deviatoi) sullo schema binari gli elementi li posiziono correttamente ma il loro nome è numero non compare? Mi potete indicare la soluzione? Grazie /* For the rest of us - translation courtesy of Herr Google */Hello I recorded 4 deviations on CS3 60226 with M83 SC 1 SC 2 SC 3 Sc4, so far ok, when I click configuration I use in the window at the bottom I appear address name time switching in black but in the address window the MM is not highlighted in well-defined black, when colloco mepparati (deviatoi) on the binary diagram the elements correctly place them but their name is not a number? Can you tell me the solution? Thank you Edited by moderator 01 June 2024 01:27:49(UTC)
| Reason: Not specified
 1 user liked this useful post by maxgand
Joined: 10/02/2021(UTC) Posts: 3,936 Location: Michigan, Troy
Anglaizie please. Most of us are best at english. I think the M83 has Italian instructions also.
Joined: 03/10/2012(UTC) Posts: 58 Location: Buenos Aires
Ciao, come hai configurato l'M83? Prima leggi l'M83 con il CS3 e poi assegna gli interruttori Saluti Guglielmo
/* For the rest of us */
How did you set up the M83? First read the M83 with the CS3 and then assign the switches Greetings William
 1 user liked this useful post by gamolina
Ci, yes by clicking on the turnout you want to assign to the M83 port terminal and dragging it there.
