#1 Posted : 12 April 2024 23:50:12(UTC)
Bryan
Dear all
I had a customer who is using a CS2 for track and analogue for the catenary at the same time. My immediate reaction was that is not quite right, I have not seen it mentioned by Marklin before. However the customer had this combination set up for quite a while without problems.
So I asked Marklin technical was this possible.
They replied as long as the grounding is the same, it can be done.
They did state that if the B terminal of the CS2 gets put on the line side of the analogue circuit then you would have big problems.
Personally I would not take the risk, just one mistake and you throw the CS out.
I am sure this would be of interest to some.
David
#2 Posted : 13 April 2024 00:09:21(UTC)
Hi David
This arrangement has been around for quite some time for instance in the powering of grade crossings.
In both cases, the common ground to digital and analog allows a safe operation. It allows also to enjoy old analog electric together with more recent digital locos.
The only warning: never allow the 16 AC to come in contact with digital.
This page was generated in 0.215 seconds.
