Offline Hoover007
#1 Posted : 03 April 2024 06:58:00(UTC)
Hoover007
Good morning gentleman. It has been years since I have posted to this forum. I am looking to see some advice from the membership. I will be traveling back to North America and thought I would buy my 60th birthday present several years early and purchase a new controller. I am currently using the Marklin 6021 control unit. I know either one of these command stations would be a massive upgrade.
I'm interested to hear the pros and cons regarding both of these units. My intentions depending on the unit I go for would be to buy a 2nd external controller (eg Marklin mobile station) to be used along with the main controller.
Any suggestions appreciated.
Robert
#2 Posted : 03 April 2024 10:32:22(UTC)
Hi Robert
Here is a Märklin fan from France having a 6021, CS1, CS2 and CS3(since 3 years).
Here is what I believe:
The CS3
- if you are mostly using Märklin locos and their decoders, then the CS3 is the unit for you. It really works FULLY in MFX which is very user-friendly
- the CS3 is also suited to configure / program all your Märklin devices (Turntable, etc)
- it allows the programming of Märklin decoders (mSD3, mLD3, mSD2, mLD2) and their sounds, using a Märklin tool: mDecoderTool3 that you can download on the M Website
- it allows the programming of all previous generations of Märklin items
- it drives MM2 (enhanced Motorola), DCC, MFX and MFX+ (allowing you to become a loco engineer)
- it allows a remote control by your phone or tablet if the CS3 is hooked to a "Box" or a WiFi router.
The ESU Ecos
- is best suited for all 2 rails digital systems and allows Railcom (feedback from locos similar to MFX).
- it is capable of MM2, DCC, M4 (a simplified version of MFX with much less possibilities) and selectrix
- is delivered with the power pack and provides 6A of digital power (the CS3 allows only 5A)
- is more more open to all recent non-Märklin standards
So in short, if you purchase mostly Märklin locos and accessories the CS3 is the unit for you. It is VASTLY more user-friendly for Märklin stuff. It is also upgraded permanently
If you are more in a diversified collection (locos from other brands with different decoders), if you are in 2 rails (the CS3 can also 2 rails) then the ECOS is a good unit.
#3 Posted : 03 April 2024 11:33:29(UTC)
Do not buy MS2! MS2 have weak softprogram so i recommended you CS3 if you want control your layout 100% digital. It is expensive system. Ecos new 50220 are also suitable system and works better with the DCC protocol and you can use Märklin trains too with this system. CS3 offer better functions. Good luck!
#4 Posted : 03 April 2024 12:41:58(UTC)
You will find that those using a ESU will think it best and those with a CS3 think it is best. I have a CS3 plus and it is great for me and works well with all things made by Marklin. If you support Marklin ( they do make your track etc) then go for the CS3. Both do the job but if Marklin bring out any changes then ESU need to catch up. IF you have a local dealer who stocks both then having a look would be good.
ASs with most things there are pros and cons with both.
#5 Posted : 03 April 2024 12:54:39(UTC)
Goofy, really? Many are using the MS2 as a primary controller. You just have to do more work than a CS3, and the screen is tiny.
It is a fine auxiliary when connected to the later unit.
As for the CS3 vs. Ecos, the CS3 is also for 2rail digital, but it doesn't have railcom like the Ecos or the Roco Z21.
The Z21 has better cab driver graphics, but it doesn't have a screen, so you must use your phone, tablet or p.c. with it.
Note that the CS3 is a total touch screen, and the Ecos has also buttons like the cs2. I admit that I was tempted to get the Ecos because of the toggle throttle controls, but got a CS3, after the MS2 because I have collected mainly Marklin since 1990.
#6 Posted : 03 April 2024 14:32:28(UTC)
You can use the CS3 with a mouse which is better than touch and works better than finger.
thanks 4 users liked this useful post by David Dewar
#7 Posted : 03 April 2024 14:57:56(UTC)
You can't use a mouse with an Ecos? I wouldn't care for that.
#8 Posted : 03 April 2024 16:48:14(UTC)
Whichever way you go, you will be locked into that brand if you wish to expand the controllers used.
The cs3 can use an ms2 or msWLAN as an additional controller. You can also get a Connect6021 to attach your existing 6021 controller as an additional throttle on a cs3.
The ECoS can use an ESU mobile control II as an additional controller. You cannot use an ms2 with an ECoS, and I am not aware that the ESU mobile control II can work with a cs3.
#9 Posted : 03 April 2024 16:57:31(UTC)
Don’t know about a mouse with an ECOS. But as I said it is good with the CS3. and is easier than using a finger or buttons.
#10 Posted : 03 April 2024 17:15:07(UTC)
It don´t need.
ESU did present a new Ecos 50220 with higher capacitive touch screen and in fact does it works more faster and nicer.
#11 Posted : 03 April 2024 17:24:58(UTC)
Yes MS2 can be use as primary control but still waste of money if you have CS3 with two control knobs.
Rocos Z21 are just black box but customer do already have phone and tablet to use as control knob and digital functions by configuration by download free app and just start drive train models.
Somebody will say it lacks for some digital system.
Personally i do see Märklins CS3 do have over ride soft program and some of them are waste to use.
If TS wants to use Märklin digital layout i would recommended only use orginal Märklins digital accessories together with CS3 to avoid digital interference.
Offline Drongo
#12 Posted : 05 April 2024 03:57:30(UTC)
Drongo
This is not quite true.
A mouse can be used to control an ECoS by using a VNC program - I use Tight VNC and it's very good.
Greg
thanks 2 users liked this useful post by Drongo
Offline bph
#13 Posted : 05 April 2024 13:37:23(UTC)
You also have the option to use your old 6021 as a 2nd controller.
if you get a CS3 you will need a Connect 6021 60128
Offline Hoover007
#14 Posted : 24 October 2024 17:32:36(UTC)
Hoover007
Thank you to everyone for your input. I ended up buying a ESU command station. I have always been a Marklin fan but the dealer in BC who stocked the unit had his store closed because of a large shipment? Ok? So while in Alberta at Hobbytech, Johnny ran me through the features and I was sold. Probably the biggest reason was ESU decoders are easier to find in Thailand while Marklin is always a order only product.
thanks 2 users liked this useful post by Hoover007
#15 Posted : 24 October 2024 20:03:35(UTC)
It´s a good choice because i find ESU sound decoder delivery more realistic sounds file than Märklin do.
Anyway...you will find Ecos new central station playful too.
Don´t forget upgrade new version by ESU to the Ecos.
Offline einotuominen
#16 Posted : 25 October 2024 11:15:32(UTC)
einotuominen
Views messages in topic : 462
About the mouse usage. I recently got the chance to acquire CS2 for very cheap price. I previosuly used only MS2 + Rocrail.
I first thought that a mouse would not bring much to the table, but boy I was wrong. Having the mouse in one hand and the other on a throttle really brings out the best in the CS2 user interface. I am sure this is even more true with CS3.
-Eino
#17 Posted : 25 October 2024 12:35:42(UTC)
My motto is as Märklin bring out locos with sound only (except a few without) stick with your CS3, if you have ESU sound decoders go with an ESU command station, like myself I keep to one system,
#18 Posted : 26 October 2024 04:22:39(UTC)
It will be fine too by use Märklin locomotives with the Ecos 50220 and i recommend use DCC protocol.
#19 Posted : 26 October 2024 08:35:55(UTC)
einotuominen
I’m running locos mixed with ESU and Märklin decoders with no problems. For a long time with MS2 + Rocrail and now with CS2 and CS2 + Rocrail. Even have my whole CAN-bus set up with Can Digital Bahn products.
No problems at all. Thou I have MFX turned off completely and drive only DCC (and FX on some older Märklin US-models)
-Eino
thanks 3 users liked this useful post by einotuominen
This page was generated in 0.684 seconds.
