Offline biswasg
#1 Posted : 11 March 2024 22:19:46(UTC)
biswasg
In the layout Construction chapters in Maerklin Magazine, the rib plans mention a number like 1260/0 or 46/30, probably depicting the ribs with resting points for baseboards. I am struggling to interpret these numbers into correct measurements.
Any help will be highly appreciated. Thanks
Gautam
#2 Posted : 12 March 2024 13:01:05(UTC)
Welcome biswag. It would help others to help by posting the magazin issue date. There are many ways to build a layout base.
It depends on the gradient ramps, and number of levels. The substrate isn't supporting a ton of weight, so the size and spacing of the cross beams is flexible. Many start with a flat solid base. Ramps, relief, mountains and tunnels can be built above.
After you have designed the track routes using planning software, you can plan for the plastering armature for relief and hills in relation to it. Also placement of scenic features and structures.
Edited by user 12 March 2024 17:16:07(UTC)  | Reason: Not specified
Offline Marklineisenbahn
#3 Posted : 12 March 2024 16:35:26(UTC)
Marklineisenbahn
Hallo,
Not sure if you referred to the same thing but most likely it is the height of track on particular rib on multi level layout!
Marklineisenbahn
thanks 2 users liked this useful post by Marklineisenbahn
Offline biswasg
#4 Posted : 12 March 2024 19:42:08(UTC)
biswasg
Thanks. I have attached an image from the plan which appeared in 06/2023 downloaded from Maerklin-magazin.de site and highlighted in red circles the numbers for which I need some clarification Image 12.03.2024 at 19.17.JPG
Gautam
thanks 1 user liked this useful post by biswasg
Offline polabear
#5 Posted : 12 March 2024 21:08:09(UTC)
polabear
Hi Biswag,
Just looking at the attached image, it appears the numbers convey (distance from left hand edge)/(height above dashed line), expressed in mm.
That, as you suspected, would establish roadbed location.
Good luck with your project.
Regards Dave
thanks 2 users liked this useful post by polabear
Offline biswasg
#6 Posted : 12 March 2024 21:21:44(UTC)
biswasg
Originally Posted by: polabear Go to Quoted Post
Hi Biswag,
Regards Dave
Thanks. It is logical and explains the numbers.
Gautam
This page was generated in 0.282 seconds.
