Offline Eddie7979
#1 Posted : 22 February 2024 00:56:06(UTC)
Eddie7979
Hi everyone,
I recently bought 2 of the Roco OBB Maria Theresia sets and have doing the LED lighting (from ESU) installs.
Question I have for you all, does anyone have any tips on removing the roof sections from Roco passenger coaches?
This kit (and some SBB ones) have clip on roofs, the clips break so easily. I’ve had to buy replacements. Last night I noticed the clips on the restaurant car was broken as well, then couldn’t find the spare part listed on Roco’s website 🙄
I have about 5 SNCF coaches that I will work on next, I am already thinking of buying spare parts already!
Be awesome to learn if anyone has a technique they are willing to share. I am considering avoiding Roco in the future and just stick to Märklin and Piko as a first preference.
Eddie
Eddie
Perth 🇦🇺
Marklin | Roco | Piko
CS3+ & iTrain
thanks 1 user liked this useful post by Eddie7979
#2 Posted : 22 February 2024 02:38:41(UTC)
Eddie, I have Roco eurofima coaches and the roof's just unclip from the sides. I have newer SBB and euro city ones and they slide off to the end by removing the diaphragm and pushing.
#3 Posted : 22 February 2024 04:05:52(UTC)
The easiest way to open the earliest design 303mm Roco coaches (Eurofima) was to separate the shell from the chassis and then to use a jewellers screwdriver to release the clips from the roof to remove the roof. Starting with the UIC-X coaches, some models then switched to a design where you could remove the roof by sliding it to one side after popping off the gangway part.
Instructions to do this are included with each model in the box.
Offline Eddie7979
#4 Posted : 22 February 2024 06:19:11(UTC)
Eddie7979
What seems to keep happening with me, the clips break off when I remove the roof. No matter how careful I am, I end up with 1 or 2 clips snapping.
I think I will need to use some glue in this case, I guess it’s somewhat lucky that that these clips are on the side. I will also see if I can find a second hand version, I noticed item 44647 seems to be the same design - this might be used for parts.
I have noticed the new designs, the sliding off and list is much better.
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline Eddie7979
#5 Posted : 22 February 2024 06:25:40(UTC)
Eddie7979
Hi Mike,
The instructions for the OBB coaches just mentions the unclipping of the roof from the top.
The bodies of the SBB and the SNCF coaches can be removed from the chassis - so I know what you mean. I will take your tip and use the jewelers screwdriver to release the clips - seems like the safer way of doing it.
I hope that the sliding design will be used in future, it will save me from the frustration in the future!
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
#6 Posted : 22 February 2024 11:45:09(UTC)
Mike, you could come over to my place: 30 minute drive and show me your debacle, 99 % of my rolling stock is from Roco and I had a couple where as the roof slid off and broke the clips, none of the others which you pull the roof off., I also could help you with the interior lights
#7 Posted : 22 February 2024 15:25:34(UTC)
Always been a problem. Works not bad opening once but if you need to get in a few times to adjust lighting or replace a passenger who has fallen off his seat that is where it becomes more likely that the roof will not clip back as it should. What we have is a cheap plastic model for which we pay a lot of cash. The least you should expect is easy entry to the interior which will always be required to repaint the one colour seats and floor etc and add lighting and passengers. Roco coaches for most run as well as Marklin and you have a better choice of models.
#8 Posted : 22 February 2024 18:18:36(UTC)
Funny timing, I arm-wrestled one of these for an hour the other day. Once you learn their assembly, it is fine, but what a job to learn...
As a more helpful reply though- I worry poor storage conditions may have brittled your plastic? I have never had an issue with this sort of thing, Roco or Marklin, EXCEPT with used items that over time I was realizing came to me from places with a lot of heat and humidity... (and presumably were not in a climate-controlled environment)
#9 Posted : 23 February 2024 02:54:21(UTC)
Roco must have had a batch of passenger carriages in the past, whereas the whole base just fell apart when I tried to take the carriage apart., never happened again
Offline Eddie7979
#10 Posted : 23 February 2024 05:21:06(UTC)
Eddie7979
Hi John,
Always good to know fellow Marklin model railroaders in Perth!
When time permits, I will definitely reach out to you and learn your techniques. I’m also happy to share any knowledge I have as well, though I’m technically still somewhat of a novice!
I have 2 more Roco OBB coaches that need the lights installed, I’m just waiting for the LEDs and some other parts.
I have checked out some of the videos you have on YouTube - it’s really impressive!
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline Eddie7979
#11 Posted : 23 February 2024 05:30:25(UTC)
Eddie7979
Hi David,
I totally agree, i also had issues where I needed to open the coach a second time.
I’m also a bit frustrated that Roco doesn’t seem to have the full list of spare parts for current models.
On this occasion, the set I have comes with 2 coaches and 1 restaurant car. Looking at the spare parts (that are all listed in German, even if English is selected), the description just comes up as being ‘roof lacquered grey’. There is no way of knowing which of the 2 coaches the roof for.
Personally, I’m really impressed with the Piko coaches. They are easy to take apart, the LEDs provide an even lighting and they also look / perform great.
There is no doubt that Roco have a great selection, I just hope they move away from the current design.
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
Offline Eddie7979
#12 Posted : 23 February 2024 05:40:13(UTC)
Eddie7979
You could have a point, it might be due to the quality of the plastics in the past too and resistance to differences in climate.
On this end, I have locomotives and rolling stock from Marklin that was purchased in Belgium during the early 80s. Moving to Australia with my parents, it was packed away in storage for a long time and exposed heat / cold temperatures at times - but always kept dry.
We don’t have many humid days here luckily.
Going through the locomotives and rolling stock, they are in good condition (luckily for me).
That said, I do try avoid buying rolling stock that is too old for concerns you highlighted but also comparability.
Eddie
Eddie
Perth 🇦🇺
CS3+ & iTrain
This page was generated in 0.440 seconds.
