Offline Stumpy
#1 Posted : 20 February 2024 13:32:40(UTC)
Stumpy
I’m currently restoring a Marklin Heavy Field Gun No 8065. I need to find out whether the spur with a screw on the firing lever underneath the gun goes above or below the axle. Before I started restoring it, it was below the axle, but the whole gun had been really messed about with. I’ve rebuilt it & left the firing lever with the spur below. This impedes elevation somewhat & doesn't allow the firing mechanism to be cocked at high elevation. Can someone help as to whether it should be above or below? If it is above I suspect someone has bent the firing lever!
thanks 2 users liked this useful post by Stumpy
Offline Stumpy
#2 Posted : 20 February 2024 14:10:37(UTC)
Stumpy
Photo before restoration, see my original post.
#3 Posted : 20 February 2024 21:46:04(UTC)
If you are a Facebook user, you might try asking on this group...
https://www.facebook.com/groups/1080130766077205 - Marklin original antique toys
Art Van Der Zouwen regularly posts images of vintage non-railway toys including some of the military items, he may have an example he can check what you want to know.
Attached image of a post from 2022
Hope this helps
Steve
Offline Stumpy
#4 Posted : 21 February 2024 17:07:25(UTC)
Stumpy
Thank you very much, I really appreciate the contact!
This page was generated in 0.398 seconds.
