Offline SamGreen
#1 Posted : 03 February 2024 20:36:36(UTC)
SamGreen
Is there an extension cable for the 60657 Mobile Station? I've tried the 60126 but it doesn't work.
#2 Posted : 03 February 2024 22:17:30(UTC)
There is no extension cable for the 10 pin connector used on the mobile stations. However if you get the 60124 adapter cable then you can plug the mobile station into the 60126 cable and then that will plug into a cs2 or cs3.
There is no extension cable that can be used to extend an ms from a track box.
#3 Posted : 05 February 2024 10:40:19(UTC)
We had reports that the 60126 cable works when you use enough force to plug it in.
Note that the MS2 plug has 10 pins while 60126 only has 9 pins. There may be one or two bent pins in that case, but they are not used.
60124 is an adapter from 10 pins to 7 pins and will not help here.
When using a Central Station 2 or 3, you can use one or more 60126, one 60125/60145 and one 60124 to extend the cable to the MS2.
Offline TrainIride
#4 Posted : 05 February 2024 16:20:01(UTC)
TrainIride
There was a hub for Mobile Station 2
Called MS II Hub (60122)
used to connect more than two MS2 to the digital box.
As it is a box with a cable, it could be used as a cable extension.
I do not know the cable length, and it seems to not be produced anymore,
but certainly available in shops.
Hope this helps
Best Regards
Joël
thanks 2 users liked this useful post by TrainIride
Offline mvd71
#5 Posted : 05 February 2024 18:01:21(UTC)
What I would like is a source for the plugs and sockets. Then I could make my own extensions to the length I want
Offline bph
#6 Posted : 05 February 2024 22:48:45(UTC)
CAN digital Bahn, used to make some:
http://www.can-digital-bahn.com/modul.php?system=sys7&modul=48#Mod_Top
you might be able to find a dealer with some left in stock.
Offline mvd71
#7 Posted : 06 February 2024 07:27:32(UTC)
Thanks, I will look into that ThumpUp
This page was generated in 0.432 seconds.
