Offline Don Mebius
#1 Posted : 17 January 2024 03:21:43(UTC)
Don Mebius
Help!
I need some M-track curved make-up pieces that are shorter than the 5205 M track.
Is there such a thing?
I have many short makeup straight pieces, but the shortest curved piece seems to be the 5205.
Any help is appreciated!
#2 Posted : 17 January 2024 11:09:19(UTC)
Hi Don
No, the shortest track section in wide radius (5200 series) is the 5205 (5° 43'°).
When I was using M track (for decades):
- using a short pieces of a different radius was no issue. Even for shorter pieces, the smallest is 8 mm long
- the M Track was rather flexible and tolerated some degree of "geometry abuse".
I never did it with M track but with C Track: to cut track pieces to what I wanted
Here is an example of a 3 way switch that has suffered of "geometry abuse" (so maybe you could do the same with M track).
The idea is to cut 2 track pieces and assemble them mechanically and electrically (glue, rail joiners and soldering) to obtain a special track piece terminated with regular extremities (joiners and center rail contact tongue)
Offline Don Mebius
#3 Posted : 17 January 2024 19:22:59(UTC)
Don Mebius
Great thoughts, thanks!
You made me think about this a little more - are there shorter curves with the 5100 series of track?
I'll see what I can do to cut a section shorter - just need to come up with a way to support the third rail.
Thanks again!
Offline analogmike
#4 Posted : 17 January 2024 21:58:12(UTC)
analogmike
Can you please post a pic of what you are trying to do? I've been doing this a long time and I never had to cut a 5205.
Offline Harvey
#5 Posted : 07 February 2024 04:11:31(UTC)
Harvey
In the 5100 series of curve tracks there is
5103 1/1 30degree
5101 1/2 15d
#6 Posted : 08 February 2024 07:55:33(UTC)
5103 1/1 30degree
5101 1/2 15d
Why stop there?
5103 is a normal 1/1 curve with feeder cables.
5102 is a 1/4 curve (7,5º)
This page was generated in 0.516 seconds.
