Offline Chuck Burkert
#1 Posted : 08 January 2024 19:06:27(UTC)
Chuck Burkert
Loco 11414.JPG11414 Loco.JPGI recently bought a used locomotive 11414. It is prone to leaving the tracks, particularly at switches. At close inspections it looks like the wheels might have a smaller lip than other locomotives. Has anyone else had this problem?
Here are two more angles of the loco.
I will test more regarding which direction it runs better and comment again.
The loco derails at switches going in each direction. My other locos don't derail at the switches so it is not the switches fault. Perplexed.
The bogies move easily, no obstruction from wires.
Edited by user 10 January 2024 22:16:16(UTC)  | Reason: Not specified
thanks 1 user liked this useful post by Chuck Burkert
Offline Dave Banks
#2 Posted : 08 January 2024 22:20:01(UTC)
Dave Banks
Could it be your missing some or all of the 4 rubber traction tyres. Can we please have a picture of the underside of your loco.
Example:
[img]UserPostedImage[/img]
D.A.Banks
#3 Posted : 08 January 2024 23:08:05(UTC)
Chuck Burkert
Example:
I’m having trouble getting a picture uploaded but all 4 traction wheels look the same as what you posted.
#4 Posted : 09 January 2024 00:45:18(UTC)
Originally Posted by: Chuck Burkert Go to Quoted Post
I’m having trouble getting a picture uploaded...
Use the paper clip on the edit bar and follow the instructions.
#5 Posted : 09 January 2024 05:08:50(UTC)
The 3050 and 3350/3650 Ae 6/6 have two wheelsets per bogie that are full wheels. The middle wheelsets are designed to allow the model to operate on tight model RR radii.
They are also designed to pivot to the sides so that the middle wheels stay on the rails and don't cause a derailment.
Regarding your derailment issues, is the loco prone to derailment more in one direction than in the other (i.e. slider in front or motor front)?
As there is no photo, I can't see if there are any obvious issues with your model, but here are a few things you can check:
1) Is the slider properly mounted? Is it aligned with the axles so that it is always in the middle?
2) Is the slider properly positioned so that it sits evenly and not with one side lower than the other?
3) The motor block and front bogie hold the plastic bogie housing in place using pins at the rear and the coupler screw in the front.
Make sure that these are properly inserted and that no part of the plastic bogie is interfering with operation.
4) You say that the loco derails, particularly at switches. Does this happen when the loco runs straight or when it takes the wye?
5) and my final thought... Open the model and ensure that no cables are caught in parts which need to pivot. Many times, models are opened and then closed and wires get snagged in a manner which prevents the bogie from properly pivoting.
I hope that this helps you harrow down the trouble.
If you still have issues, please post a photo of the underside of your model along with a short video of the model running over a switch in both the straight and turnout tracks.
Offline Dave Banks
#6 Posted : 09 January 2024 20:41:06(UTC)
Dave Banks
Ok here is the picture of the loco in question from Chuck Burkert:
I must say it looks like all traction tyres are intact. We need to look at the rear of the loco & see if there is any up & down play in the three rear axles.
This kind of wear can occur from heavy use especially when the loco goes in one direction all the time. The loco can adopt a lopsided look as if it has a puncture.
Just a thought & process of ticking off the possible causes of your derailment.
D.A.Banks
#7 Posted : 09 January 2024 21:32:40(UTC)
First thing that I noted in the photo is that there seems to be oil seepage on the bottom of the motor block.
I see what appears to be normal wear on the traction tires.
Please check the rest of the items on my list above.
#8 Posted : 16 January 2024 19:23:39(UTC)
Chuck Burkert
Thank you for the tips. I continue to investigate the issue.
Offline aos
#9 Posted : 06 September 2024 14:40:23(UTC)
aos
Hi Chuck,
As Mike says: The middle wheelsets are designed to allow the model to operate on tight model RR radii.
They are also designed to pivot to the sides so that the middle wheels stay on the rails and don't cause a derailment. For pivot, read play/slack in the middle axle.
I have exactly the same problem. My loco always worked a dream on the old M track. Some years back, I serviced my loco and converted it to digital. I also converted my track to C track. Since then, it has always derailed on the 24620 double slip points. After my conversion, I had put my wheels back on the middle axles too tightly, thus not allowing for any play. This caused the inevitable derailments.
It was only last night when reading Mike's post that I realised my faux pas.
I spread the middle axle wheels apart ever so slightly and she now runs a dream again. Give it a try. In fact, make sure that there is a few millimetres clearance on all wheels. Good luck, Alan
thanks 2 users liked this useful post by aos
Offline 60904
#10 Posted : 12 September 2024 10:47:02(UTC)
60904
Good morning,
which track do you use? M or C. This model should run perfect on C or M. But, are you sure it is not a rebuilt HAMO model? The hole in the bogie has been there for the Fleischmann Pilzkontakt. Maybe it has been taken away. Check if the wheels are DC or AC.
Martin
thanks 1 user liked this useful post by 60904
#11 Posted : 12 September 2024 12:41:27(UTC)
Check the wheels gauging. Depending on the type of rails you use, it should be 13.8-13.9 mm (M-track), It can be bigger for C-track. (I think upto 14.1mm, but I dont use C-track myself, so have no experience)
I.e you need to meassure the distance of the inside of the wheels flanges...
Also; Are you doing the test with or without waggons? (Maybe the trailing waggon foils the buffers...)
Also II; Are the traction tires all of the correct type and size? -They must adhere to the correct wheels diameter when installed, and should not be twisted or loose.
#12 Posted : 12 September 2024 13:56:07(UTC)
Here are a couple of things to verify:
1) The bogies are plastic inserts which are clipped into the metal from the rear and then fixed in place by the screw which holds the coupling shaft.
- Make sure that the parts are properly seated and that the coupling screws are properly tightened
2) The motor is held to the chassis by two slots into which the undercarriage fits.
- Make sure that the undercarriage is not bent or otherwise misshapen which would affect the ability of the motor to pivot.
3) The bogies have replications of the brake shoes.
- Make sure that these are sitting properly and that they are not contacting the wheels or the rails
- Test the locomotive with the shell removed, so that you can observe the motor as it pivots
- Ensure that the cables are not impinging on the pivoting of the motor block
- As an additional test, remove and reinstall the slider in the inverse direction or install a replacement slider to see if that improves the operation.
You can also remove the slider and test using the catenary to determine if the slider was causing any issues.
This page was generated in 0.403 seconds.
