Offline revmox
#1 Posted : 28 December 2023 01:25:37(UTC)
revmox
I picked up 3 Marklin decoders in a box of assorted parts. They have KN150211 on the PCB and I was told they all came from the yellow loco (ML00610) in the 29253/51430 Aldi sets sold in Australia.
That's all very straight forward but searching the net and forums has left me a bit puzzled. I presume that these simple non-sound mfx decoders are probably fitted to many startup and basic set locos.
Different locos at this level all have different part numbers for their decoders, for example -
ML00610 E261368 (the Aldi set)
89 class E283792
81 class E306426
74 class E353405
216 class E353466
Do all these locos actually have the same physical decoder with a few settings changed such as loco name and maybe some parameters tweaked for better operation?
If so, is there an original "base" decoder that can be programmed to replace all of the above?
If so, what is the part number and what are the specs?
Cheers and thanks.
Offline Bill L
#2 Posted : 28 December 2023 05:12:49(UTC)
Bill L
Was curious and did a search.
https://www.marklin-user...in-Starter-Set-ID--29253
Looks like the color coded wires are the standard color ones.
But looks like there are no F1-F4 functions. The author describes the controller to be simple but did not include a picture. Curious what the motor looks like.
You may have to wait for other inputs from other people familiar with this set.
Offline revmox
#3 Posted : 28 December 2023 08:01:20(UTC)
revmox
Hi Bill,
The motor is just a simple can motor, 2" or 50 mm long.
The decoder normally just has motor and light outputs but it seems some people have squeezed an extra function or two out of it.
I've got three of these decoders and was just wondering what they could be spares for.
If your 89 class decoder dies I imagine any you could just grab one from another startup loco to do the repair.
What surprises me, or I've just missed it somewhere, is that you don't seem to be able to just order a "generic" startup decoder.
I've just spent the afternoon fitting one to the analogue loco in the 2858 set. Works fine.
#4 Posted : 28 December 2023 20:13:21(UTC)
Cheers and thanks.
I believe these are based on the 60760 decoder - although the 60760 does not have mfx.
Offline revmox
#5 Posted : 28 December 2023 22:16:26(UTC)
revmox
Hi kiwi,
I received the 2858 set as a surprise Christmas present - boxed and unused.
I immediately fitted it with the 60760 digital conversion kit - and, as you say, that decoder doesn't have mfx.
I swapped in one of the "unknown" mfx decoders from the startup bits and pieces just out of curiosity.
To me, and probably other novice users, the mfx solution is a little easier.
I think it runs smoother with the mfx decoder but I don't know why that would be the case.
Offline mvd71
#6 Posted : 29 December 2023 08:43:51(UTC)
The mfx decoder may have more speed steps that the decoder form the 60760 kit. This often makes them appear t9 accelerate/decelerate more smoothly.
This page was generated in 0.293 seconds.
