Offline dave55uk
#1 Posted : 06 December 2023 17:38:21(UTC)
dave55uk
Is there a way of swapping the red/green position of a set of digital points?
i.e., making the turnout the green and the straight the red.
#2 Posted : 06 December 2023 17:44:21(UTC)
Can always be done with a soldering iron, assuming you use decoders in the trackbed.
Simply swap wires when using external k83/m83 decoders.
Some controllers allow to swap turnout function in the UI (not the MS2).
Offline dave55uk
#3 Posted : 06 December 2023 18:32:24(UTC)
dave55uk
Me? Use a soldering iron near anything remotely delicate? Oh no. LOL.
#4 Posted : 06 December 2023 18:56:35(UTC)
So the other options are UI (ECoS or Central Station) or external decoders k83/m83.
#5 Posted : 06 December 2023 23:18:50(UTC)
Why would you want to do that.
Offline dave55uk
#6 Posted : 07 December 2023 13:06:53(UTC)
dave55uk
(the bottom / is a point, not a crossing and ignore the dots)
So the bottom line is a shunt spur to the left of the point and goods sidings to the right.
The track coming in from the top right continues on the top line - therefore the points act
as a crossover (and so the top point would have to have green/red reversed).
That's why I want to do that.
Are C track points power routing? (General MRR)
by ChrisWV10 14/01/2018 13:22:56(UTC)
This page was generated in 0.262 seconds.
