Offline Alex H
#1 Posted : 20 November 2023 12:33:36(UTC)
Alex H
Good morning.
I am currently setting up an HO layout using Marklin C track with a Z21 (black) controller and iTrain.
I am looking to install occupancy detection and was wondering what other members might recommend as being trouble-free and easy to set up detection systems.
Very many thanks for suggestions.
Alex
Offline blid
#2 Posted : 20 November 2023 14:54:11(UTC)
blid
I used S88 with Littfinski LDT RM-88-N-Opto. They are old but work well with C-track. I cut all my tracks (not turnouts) on the underside so that the rails were no longer electrically connected. That way the cars with 3-rail wheels were also detected.
I don’t know if the Z21 has a S88 port. When I started with feedback I had already decided to go with a PC-program and LDT HSI-88 for S88 directly to the PC. iTrain supports the HSI-88.
#3 Posted : 20 November 2023 23:29:06(UTC)
Originally Posted by: Alex H Go to Quoted Post
... install occupancy detection ...
You may wish to expand on your meaning of this.
If you are using software and implementing some sort of block control then a block may be considered occupied by a "point" sensor (or even logically by the PC without any sensors) as the train enters the block.
If you do want to detect if an actual train (locomotive or power drawing wagon) is in the block/section you may use something like the m83-AC(sic) 60882 that detects based on current draw.
Note; this solution falls down if the track power is off
for non locomotive (no power draw) detection , 3 rail systems offer this passively by isolation the rails.
Note; this system falls down of you have wagons with isolated axles.
If your concern is loosing coaches (unexpected un-coupling), then a reed switch solution for the caboose with a magnet may offer a tracking solution.
Analog Track Occupancy Detection (H0-scale)
by Brian_BR96 13/11/2022 04:27:02(UTC)
Question concerning track occupancy detection (Digital)
by Chris6382chris 06/11/2010 07:07:08(UTC)
This page was generated in 0.336 seconds.
