Offline Eddie7979
#1 Posted : 13 November 2023 04:04:19(UTC)
Eddie7979
Hi fellow railroaders,
I recently bought the SNCF BB Série 67400 Strasbourg from REE Modèles (MB-167SAC), this is my first from this company.
I usually like to stick to Marklin but I was looking to expand my diesels from the SNCF. Opening the box, I found a few small plastic pieces needed to be re-attached to the model and buffers needed to be re-aligned.
Running it, I could hear a repetitive clicking sound in which then caused a short circuit as it went over a switch. At first, I thought the locomotive wasn’t sitting on the tracks properly but this wasn’t the case. I suspect that the issue is with the slider, on inspection it does sit straight but have found it is not as firm as the Marklin / Roco sliders (whether this has any relevance in terms of operation).
I’m contemplating fitting a Roco slider and then see how that goes
My question, has anyone experienced similar issues with REE Modèles?
If so, what have you found works best?
Eddie
Eddie
Perth 🇦🇺
Marklin | Roco | Piko
CS3+ & iTrain
This page was generated in 0.201 seconds.
