Offline Mr. Ron
#1 Posted : 01 October 2023 00:38:47(UTC)
Mr. Ron
I am using M track on my layout and have a lot of wire running under the layout's baseboard. I am thinking of running all wiring within the base of the M track rather than under the baseboard. Has anyone done this? There appears to be a lot of empty space within the M track sections.
#2 Posted : 01 October 2023 13:14:47(UTC)
Not if you are screwing down the tracks. There may be possible interference of current and digital signals. Do one long section and test it out.
Offline heinrichhess
#3 Posted : 01 October 2023 13:26:10(UTC)
heinrichhess
yes i run under m track and all so cross sections as well like other person says if you are fixing it perinatally down and need to fix it may be a problem how ever you get same problem if a switch motor needs fixing
hess
thanks 1 user liked this useful post by heinrichhess
Offline FastEddie
#4 Posted : 27 October 2023 14:58:52(UTC)
FastEddie
If you run your wires from both track and switches under the M track won't that require a lot more wire? How do you collect all your light wires and power wires from switches into distribution strips if not under the board? I run k track now but I did run M track for years and everything was under the board. I organized things using plastic wire holders and staples to channel the wiring.
thanks 1 user liked this useful post by FastEddie
Offline BenP
#5 Posted : 27 October 2023 18:36:03(UTC)
BenP
That works ok for a temp layout, but not well for a more permanent or larger layout. Wires are more easily connected and combined (and error checked) under base.
Just my opinion. Ben
Ben van der Pluijm--
thanks 2 users liked this useful post by BenP
Offline bygger01
#6 Posted : 12 November 2023 20:56:20(UTC)
bygger01
My advice is:
Choose a color for center conductors + rail ( red & black/brown will be suitable ).
Use a drill with a suitable thin drill for a wire from a rail + one from the center conductor, which is soldered on.
Drill the two holes below, where the rail should be.
Down with the two wires (Use long wires of 2-4 mtr, so that when you have solder, there is for the next wires.
Under the table top you have drawn 1.5 square meters of solid wire (again in red & black/brown) and to these two you solder 2 thin wires.
Keep the two wires separated by 5-10 cm and insulations are unnecessary.
Use soldering and forget about anything with screws!
This is how you continue with wires from the rails every 1-2 mtr.
Jørgen St. from Herning in DK
H0 / Märklin K track / CS3+ / full digital / Epoke III +/-
#7 Posted : 12 November 2023 22:29:21(UTC)
Hi Mr Ron
Running wires under the M trackbed is not a great idea (Pardon me). Why?:
- much longer wiring
- much less maintainable (doing a change is hell having to unscrew a lot of tracks
- why not use wiring ducts (see image below). They exist in different shapes and size. They are U-shaped and closed by a clipsable top so making changes is a piece of cake
Offline bygger01
#8 Posted : 13 November 2023 00:37:10(UTC)
bygger01
I want to make it simpler, because those boxes cannot be soldered in!
Instead, I will drill suitable small holes with e.g. 10 cm gap in the cross boards, which are normally part of the table construction and pull the continuous ring wires through (red & brown for the digital and maybe yellow & blue supply current for switches and signals).
Offline Mr. Ron
#9 Posted : 14 November 2023 01:32:48(UTC)
Mr. Ron
Hi Mr Ron
At 89, it's hard to work under the layout. I am also confined to a mobile scooter. All my work has to be above the layout where I can reach.
This page was generated in 0.628 seconds.
