Offline heinrichhess
#1 Posted : 21 September 2023 13:23:11(UTC)
heinrichhess
got 3 loco's in fleet I like there driving characteristics and look grate the reason for upgrade is i want to turn on and of light's and smoke this is the only reason for up grade any recommendations welcome using MS2 and analogue power cutting semaphores
hess
#2 Posted : 21 September 2023 15:13:07(UTC)
It depends on if you want sound. Newest ones are mfx.Otherewise, you'd be shopping for reliable used or new old stock fx. Old 6090, and 6091,91c have 4 functions.
#3 Posted : 21 September 2023 15:59:39(UTC)
heinrichhess
not after sound and MFX will not go into the slot on the controller they add them self's automatically on the next free slot is MFX the only new option?
hess
Offline tonyfh
#4 Posted : 21 September 2023 18:25:40(UTC)
tonyfh
Hess,
As far as I can see on your foto's these decoders are early Delta ones with 4 dipswitches only.
These decoders show only lightning when the loc is running like in the old analog days.
In case you want the lights always on and don't want sound you can convert these locos with the Märklin decoder 60906, this is a modern decoder without sound suitable for old style fieldcoil motors, see also this topic.
These decoders aren not the cheapest but more or less the most simple conversion.
Succes, Tony.
thanks 2 users liked this useful post by tonyfh
bphBenP
#5 Posted : 21 September 2023 20:16:04(UTC)
heinrichhess
Originally Posted by: tonyfh Go to Quoted Post
Hess,
Succes, Tony.
yes old delta that is grate news will look out for 3 of them will they also control smoke unit?
Offline mvd71
#6 Posted : 22 September 2023 09:08:57(UTC)
Hi Hess,
From what you have said it seems the marklin 60906 decoder would be the best option for you.
This will allow you to change the decoder only and re-wire the lights and smoke, then you will get exactly what you want.
Cheers….
Offline BenP
#7 Posted : 22 September 2023 15:57:44(UTC)
BenP
I have used a 60906 decoder in several conversions where I did not (or could not) change the original motor (like vintage steamers, 3015 croc), with great success. Even low speed driving is pretty good with old motors, though not the same as 5-pole replacement.
Ben
thanks 3 users liked this useful post by BenP
Offline cintrans
#8 Posted : 23 September 2023 02:00:06(UTC)
cintrans
Aruba
Hess
The C80/6080 decoder (old 8 dip-switch delta decoder) has one function (F0) that can be wired up for lights, telex or smoke...
Jean-Pierre
This page was generated in 0.311 seconds.
