Offline BenP
#1 Posted : 09 September 2023 16:02:05(UTC)
BenP
I want to convert my Z layout to digital. I have unused marklin 6021 control boxes and an intellibox (v1). Can they be used with 12 V power supply instead of regular 16-18 V track power. Particularly, will 6021 accept low voltage Z transformer as power supply? Secondly, can intellibox be set for 12V digital output?
I know the alternative is a DSR placed between the control station and track, but wonder about control station options first.
Ben
#2 Posted : 09 September 2023 18:19:02(UTC)
Hello Ben
Sorry for being a "oiseau de mauvaise augure" (bringer of bad news).
Here is the little I know:
- The Märklin 6021 digital languages are Motorola and MM2 (the enhanced Motorola) issued in 1995.
- I cannot say anything on the Intellibox 1. Is it DCC-capable? The 65150 is. Is it low voltage- capable? I don't know
- the Digital central unit must be DCC-capable, accept low voltage required by Z trains (closer to 10 V than the 19 V of the Märklin ones)
- the key issue is to digitalize locos. A German manufacturer (VELMO) provides replacement PCBs to digitalize some Märklin Z locos. These are using DCC and require no machining of the chassis
Look here for information https://velmo.de/html/english.html
I suppose that preference must be given to large Diesels or Electrics
An extra clean layout is needed so a tight cover must be considered.
I am a big fan of Märklin digital and PC control (Rocrail) so yes, digital brings a huge improvement to your layout.
Here is mine (sorry HO and MFX)
https://www.youtube.com/watch?v=F6WnhXPcRqI
Offline einotuominen
#3 Posted : 10 September 2023 16:10:54(UTC)
einotuominen
I have not done this myself as I want to drive Z analogue. However what you will need is a digital voltage reducer.
The full setup would be:
CS3/MS2 —> voltage reducer —> track —> Velmo decoder in loco —> loco
See this: https://amw.huebsch.at/produkte/dsr.htm
There is english text at the bottom.
Please guys, correct me if I’m totally wrong.
Other approach would be to go Digitrax. They too have drop in loco decoders for Z. See: https://www.digitrax.com...s/engine-matrix/decoder/
And: https://www.digitrax.com...ir-radio-receivers/up6z/
-Eino
Edited by user 14 September 2023 14:45:50(UTC)  | Reason: Fix typos.
thanks 2 users liked this useful post by einotuominen
Offline BenP
#4 Posted : 14 September 2023 14:21:48(UTC)
BenP
Thx for sharing the key information for doing Z digital (voltage limiter and decoders). I'll begin with adding catenary to control 2 trains on one track and then try digital. Some of my (vintage Z) locs do not have a decoder option.
Ben
Offline BenP
#5 Posted : 27 January 2024 02:34:38(UTC)
BenP
I bought a MS2 and variable DC power supply for some experimenting and learned that the MS functions at any voltage greater than 10V. So, it can be used for 10-12V digital control of Z aftermarket decoders. Unfortunately, the seller Velmo no longer mails to US because of package losses (I regularly order from Germany and never lost anything yet).
Thus, sticking with analog track and catenary power for now.
Ben
#6 Posted : 27 January 2024 08:16:59(UTC)
einotuominen
Well you should definitely look at the Digitrax offering then.
-Eino
Offline BenP
#7 Posted : 27 January 2024 14:14:19(UTC)
BenP
-Eino
How's the fit for Marklin locs (incl lights) and what are people's experiences with them?
Ben
#8 Posted : 27 January 2024 14:30:48(UTC)
einotuominen
Unfortunately I don’t have personal experience, but they do have products like this one for example https://www.digitrax.com...obile-decoders/dz123mk1/
-Eino
Original Lenz digital addresses (Big scale)
by gcanton 24/10/2011 18:32:28(UTC)
This page was generated in 0.403 seconds.
