Offline ocram63_uk
#1 Posted : 02 September 2023 13:42:23(UTC)
ocram63_uk
Hi folks, the coaches I have bought second hand have the wheels full of gunk, can scrape this away, but are very dark. Is there a 'clean' way to get them back to how they were? Dremel with copper brush, ultrasonic bath in ammonia solution, other?
I've ordered new 7198 shoes but pushing the coaches on the tracks the lights flicker. Also ordered new warm light LED to replace the bulbs 😊
Thank you
Marco
#2 Posted : 02 September 2023 14:30:29(UTC)
Drugstore alcohol and a cotton swab or toothpick.
Offline ocram63_uk
#3 Posted : 02 September 2023 14:32:06(UTC)
ocram63_uk
isopropyl alcohol just the same?
#4 Posted : 02 September 2023 15:23:45(UTC)
15%
#5 Posted : 02 September 2023 16:25:42(UTC)
Views messages in topic : 8,251
I recommend the Hag Old Generation Slider (518). I installed this on my SBB lightsteel consist to power the taillight and I love the way it clips onto the bogie and is much better designed than the original Maerklin 7075 which had to be screwed to the bogie.
Hag: https://www.amiba-shop.c...gen-der-alten-Generation
Maerklin: https://marnan.eu/artike...or-oudere-rijtuigen.html
As far as cleaning, any isopropyl (rubbing) alcohol will do.
Offline Toosmall
#6 Posted : 02 September 2023 16:27:08(UTC)
Toosmall
Lighter fuel & cotton buds. Maybe the odd scalpel blade. That's what I use on Z gauge.
(Australia)
https://www.bunnings.com...ers-1l-shellite_p1563463
Offline ocram63_uk
#7 Posted : 02 September 2023 17:15:56(UTC)
ocram63_uk
Thank you all. I have to buy a new tin of Zippo fluid so I'll go down this road 😊👍🏻
Offline 1borna
#8 Posted : 02 September 2023 20:49:17(UTC)
1borna
Croatia
Any cleaning with a knife, brass brushes or the like damages the surface of the wheel and leaves grooves in which dirt collects even more easily!
Dirt layers can be thick and hard, it is best to leave the wheels in a covered container with alcohol all day to soften
How often is it enough to wipe the wheels well with a cloth
In more difficult cases, I make small circles with a sanding sponge that removes hard layers on a drill (Dremel and similar) and finally repeat the process with a cloth
thanks 3 users liked this useful post by 1borna
Offline Michael4
#9 Posted : 02 September 2023 23:45:22(UTC)
Michael4
Rather surprisingly Tesco sell lighter fluid at the cigarette counter (well maybe not that surprising!)
Offline ocram63_uk
#10 Posted : 03 September 2023 13:56:54(UTC)
ocram63_uk
NOT my Tesco Express. The Off License does though 👍🏻
This page was generated in 0.328 seconds.
