Offline heinrichhess
#1 Posted : 31 August 2023 11:56:04(UTC)
heinrichhess
really like the look of this set buy marklin how ever not a fan of MDF painting is a real problem as the material soaks up paint like a sponge and card printed details don't look real or take weathering would be nice to hear if somebody has brought 1 and if they are happy with it
hess
#2 Posted : 31 August 2023 17:46:35(UTC)
When you say 'printed' I assume you mean 'painted'. I don't believe they use MDF, rather thin wood as used to make plywood, which is then laser cut and painted. so on purchasing the kit it should build up in the colour illustrated.
Offline applor
#3 Posted : 01 September 2023 03:38:15(UTC)
applor
You can weather these if desired using paint pigments or pastels. I haven't tried using paints but haven't needed to since the advantage of these is the nice flat colour finish and the glue doesn't stain, unlike your standard shiny plastic kits glued with solvent.
#4 Posted : 01 September 2023 13:51:51(UTC)
heinrichhess
thanks all i find it hard to move away from plastic
hess
Offline Toosmall
#5 Posted : 02 September 2023 05:59:07(UTC)
Toosmall
Or build your own out of high impact styrene.
A few tips down this page:
https://www.marklin-user...er-kit-building-services
1:200:
1:100:
All out if styrene.
thanks 5 users liked this useful post by Toosmall
Offline dickinsonj
#6 Posted : 03 September 2023 01:22:10(UTC)
Nice models Johnathan.
Kind of out of reach for most of us however. In truth they are art, rather than craft IMO.
Thanks for posting those - they are a joy to behold.
Offline Toosmall
#7 Posted : 03 September 2023 09:47:48(UTC)
Toosmall
The buildings are just architectural marketing models. The hardest thing building them is when the architect gives you crap drawings (full of mistakes) & it takes so much longer to build it.
The building at the top of the tread with 3 roofs is not difficult. It's all straight surfaces. The dark lines, just spray strips & stick them on after. Easier than trying to mask for painting. Roofs paint separately.
The windows are not difficult, just tedious. I would score grooves on to polycarbonate (one whole elevation at a time, which then is behind the wall) & rub kids acrylic paint in, but one could build them up out of strips. Cut a square hole in a piece of cardboard as jig for an overall frame, then fit pieces within. Paint, then stick on the building.
This page was generated in 0.389 seconds.
