Offline Mille
#1 Posted : 27 August 2023 12:42:46(UTC)
Mille
Can i have Märklin digital signals on
Märklin bridges for C track?
thanks 1 user liked this useful post by Mille
#2 Posted : 27 August 2023 14:20:47(UTC)
I havn't done it, but if the decoder fits under the track, or you can hide the wires then I don't see why not. Maybe route the wires from under the bridge by drilling a hole, then fit the deoder on the bottom of the ramp, then connect the signal and secure it.
#3 Posted : 27 August 2023 14:27:14(UTC)
Hi Mille
Here are my thoughts on the subject. I do have both C Track bridges and digital signals but I never implemented a signal on a bridge.
I believe semaphores (like 70392) could be implemented (normally on the right side, in Germany) but this requires a large surgery of a straight bridge with a significant "overgrow" of the mechanism outside of the bridge which distances with a prototypical aspect.
Regarding light signals, it looks better and seems to me:
- there is no implantation on C-Track bridges without doing a minimal surgery of the bridge and of the signal connector support to keep only the connector and the mechanical locking of the signal.
- this is only possible on straight bridges as with curved bridges, even in absence of signals some Märklin units bump on railings
- of course, the digital relay must be located under the table.
- Viessman Light signals have a "Steckfuss" which requires drilling a 5.5 mm diam. hole which also will be difficult to hide unless using the signal base 4733 and doind some surgery.
Offline Mille
#4 Posted : 27 August 2023 16:23:43(UTC)
Mille
Thanks for information
Any good Idea for wiring between my
two levels of tracks?
#5 Posted : 27 August 2023 17:03:38(UTC)
I think you have these solutions:
- drill a hole into all pillar segments and near the bridge separation
- have the cables hidden between the rails and the bridge
- a combination of these solutions
This page was generated in 0.302 seconds.
