Offline brauer.jim
#1 Posted : 09 August 2023 06:13:55(UTC)
brauer.jim
BigGrin Well, I am finally getting ready to hook up my turntable 7686 to the digital controls 7687,
BUT Cursing
I can't find the cable that should be right there with it.
So my question is, how do I find a 6 pin cable that can be used?
Your help is very much appreciated.Cool
Jim Brauer
Getting restarted after 15 years!
Offline franciscohg
#2 Posted : 09 August 2023 06:28:06(UTC)
franciscohg
Chile
Hello
You should be able to connect 7686 to 7687 directly with the ribbon cable of 7686.
Offline brauer.jim
#3 Posted : 09 August 2023 06:31:45(UTC)
brauer.jim
Yes if only I could find it, so I am trying to understand what other cable just might be usable.
thanks for answering
Jim Brauer
Offline franciscohg
#4 Posted : 09 August 2023 06:59:29(UTC)
franciscohg
Chile
Mmmm, are you sure that your TT works in the first place ?
Anyway, IIRC the conector is the same of old s88. You can buy a cable at LDT and use it to rewire your TT.
Can check that tomorrow when i go back home.
Regaeds
Offline franciscohg
#5 Posted : 09 August 2023 17:52:38(UTC)
franciscohg
Chile
Well, my memory was fine, a standard s88 connector will fit in the 7687 port.
You can get an old marklin s88 cable or get a new one here
https://www.ldt-infocent...for_the_s88-feedback_bus
available in several lenghts
#6 Posted : 09 August 2023 18:16:16(UTC)
BUT Cursing
Hi Jim
I may be totally wrong but a Märklin turntable 7286 (not 7686 which is an outdated decoder) has a flat cable soldered to it.
Here is the bottom of my 7286 TT with the colour assignments
So either you have a modified TT or you are dealing with a Fleischman version without a flat cable 6652 or the latest re-edition 665201.
Here is the user's manual file:///C:/Users/brucy/D...%20Betriebsanleitung.pdf
See page 2 for the wiring, and cable colours
So it is the exact same TT as for Märklin with 2 differences:
- flat cable for M£ärklin
- different resistor values (under the bridge) in series with the motor to cope with 14 or 16 VAC
I hope this helps
Here is my Märklin 7286 TT with a different decoder
Offline Dave Banks
#7 Posted : 09 August 2023 20:58:05(UTC)
Dave Banks
[img]UserPostedImage[/img]
D.A.Banks
Offline brauer.jim
#8 Posted : 09 August 2023 21:03:16(UTC)
brauer.jim
Thank you very much! You are absolutely correct. I do have a 7286, and the wires are soldered to the base with the 6 pin right there where it should be.
As a novice to this journey and creation, i very much appreciate those of you who know your marklin inside and out! Great video!
Jim Brauer
thanks 2 users liked this useful post by brauer.jim
Guest (5)
This page was generated in 0.320 seconds.
