Offline heinrichhess
#1 Posted : 21 July 2023 15:32:40(UTC)
heinrichhess
Views messages in topic : 214
looking to buy Schicht 31/1100 HO Gauge Deutsche Reichsbahn what are running quality? i have m track standard switches no crossovers and have 3% grades and 5120s
hess
thanks 1 user liked this useful post by heinrichhess
Offline franciscohg
#2 Posted : 21 July 2023 16:18:04(UTC)
franciscohg
Chile
Hello
I have those cars and run them o M Track 5100/5200 curves and 5% grades. You need to change the wheelsets for Märklin équivalent and they run fine.
Regards.
thanks 3 users liked this useful post by franciscohg
Offline dickinsonj
#3 Posted : 22 July 2023 01:50:21(UTC)
And they certainly are nice looking coaches!
#4 Posted : 22 July 2023 04:47:20(UTC)
heinrichhess
thanks all looks like a lot of wheels needed
hess
Offline scarfo
#5 Posted : 22 July 2023 11:12:10(UTC)
scarfo
India
hess
Hi Hess
I have both these sets and run them as a four car unit.
The wheel sets should be the standard schicht/piko of the time in which case it is quite easy to take them out one by one and twist the insulated wheel ( with the plastic inner bush with the intention of moving it in about 1mm - i just did it by eye, and them measured with a capliper for 13.9 to 14 mm back to back. The wheel dimensions are quite coarse - about the same as older marklin stock, so there is plenty of tread width available.
They run absolutely fine on all 3 marklin tracks - M K & C.
You will need to attach the coach units together using the outer holes to give a wider spacing for use on M 5100 and 5120 curves.- this is more a factor of the geometry of articulation than the wheel back to back.
Have fun
Charles
#6 Posted : 23 July 2023 17:24:40(UTC)
heinrichhess
got 4 sets of ebay so 8 cars so 28 old wheel sets needed so 14 old coaches of to the scrap thanks for the advice about attach the coach units together using the outer holes will update when they arrive thanks scarfo
hess
This page was generated in 0.380 seconds.
