Offline Peter Pop
#1 Posted : 20 July 2023 08:52:43(UTC)
Peter Pop
Train goes tilt after adding the final two coaches. Also fails to register at that time.
Running the 39716 only 7 functions show up on the cs3plus.
Anybody else has a similar experience? Any suggestion other than sending it back to the dealer?
thanks 1 user liked this useful post by Peter Pop
#2 Posted : 20 July 2023 13:15:31(UTC)
You have been a member since:: 10/02/2021(UTC)
I don't have an ICE4, just a 3. Are you coupling the coaches in order as the manual shows? Do you have your CS3 set for MFX, and the correct amperage/wattage in the settings?
Might you have a signal or braking block in your track whereas the last coaches could be causing a short by overlapping with another block, contact track area or switch?
Once the model is registered in as MFX, it stays there. What happens if you operate it before adding the last 2 coaches, cut the layout power with the CS3, then couple then on and try running it?
The only reason I can think of why only 7 functions are showing up is a decoder fault, or you have mfx disabled. Try deleting the train, and re-register it. Shut down you CS3 with the screen system menu, not the stop bar. Once it's offf, shut off the line power strip/surge protector, or unplug it from the outlet.
Offline Peter Pop
#3 Posted : 20 July 2023 15:50:49(UTC)
Peter Pop
Thanks, did all that many times over. Worried that alll the connecting and disconnecting will give another set of problems
#4 Posted : 20 July 2023 16:03:42(UTC)
Your ICE 4 should still be under full warranty! Contact your dealer, or Marklin USA, or Germany if you bought it from there.
#5 Posted : 20 July 2023 20:51:45(UTC)
What is 'tilt' ? Is it falling over?
The decoder and motor I think are all in the restaurant car.
#6 Posted : 21 July 2023 14:16:44(UTC)
He meant TILT as a short fault. At least how I interpret it.
This page was generated in 0.288 seconds.
