Offline heinrichhess
#1 Posted : 21 June 2023 21:28:24(UTC)
heinrichhess
brought this cards of e-bay will not work any ides or links to an e-bay card that will work
10 Packs ISO7816 RFID Contact SLE 4442 Chip PVC Smart IC Cards Wholesale Lot
#2 Posted : 21 June 2023 21:39:44(UTC)
Cards that are known to work have these specs:
"Chipkarte mit I²C-Bus E²-Prom-Speicher 8 kByte (64 kbit) Chip: Microchip 24LC64 6-pol ISO-Format 85,7 x 54 x 0,81 mm"
RFID is not used.
Offline ocram63_uk
#3 Posted : 23 June 2023 16:43:48(UTC)
ocram63_uk
out of curiosity, what are these cards for and where do you insert them?
#4 Posted : 23 June 2023 16:53:45(UTC)
They store information about a loco (AKA loco cards). You can insert them into MS2, CS2, and CS3.
Some use them for backups.
Some use them for quick selection of locos.
They can also be used to quickly register a loco e.g. at club meetings.
#5 Posted : 23 June 2023 17:36:36(UTC)
heinrichhess
Im thinking £7.00 each is not a good buy Confused which is all e-bay has so must start shopping around for them
https://www.ebay.co.uk/i...O%7Ctkp%3ABk9SR87Wo46dYg
hess
Offline ocram63_uk
#6 Posted : 24 June 2023 06:54:05(UTC)
ocram63_uk
Tom, so they are a kind of memory expansion for locos on the control sets.
#7 Posted : 25 June 2023 18:26:23(UTC)
Not really. They are read when you push them in and can be removed immediately. As I said, they provide an easy way to select locos.
If you use the MS2, but have more than 40 locos, they can be considered a memory expansion.
This page was generated in 0.541 seconds.
