Offline einotuominen
#1 Posted : 21 June 2023 06:12:19(UTC)
einotuominen
Hi guys,
By this photo, looking at the motor shield, can you say is this DCM or SFCM motor?
The 3038 appparently have two versions been produced back in the days.
Thanks!
-Eino
#2 Posted : 21 June 2023 07:47:16(UTC)
This is FCM, not DCM.
With two brushes side by side, the motor is FCM, not DCM.
#3 Posted : 21 June 2023 08:20:56(UTC)
einotuominen
Ok thanks,
Which of the new retrofit motors should I choose for this?
I don’t currently have access to this loco so I can’t open the motor and see what the armature look like.
-Eino
#4 Posted : 21 June 2023 08:30:11(UTC)
The 60943 is the conversion set for SFCM.
#5 Posted : 21 June 2023 11:14:11(UTC)
einotuominen
Thanks!
-Eino
Offline pederbc
#6 Posted : 21 June 2023 12:50:58(UTC)
pederbc
Here’s a good website to find the motor type used in older loks.:
http://www.bahn.hfkern.de/Maerklin/Menue.html
Br, Peder
#7 Posted : 21 June 2023 12:59:15(UTC)
Thanks!
-Eino
If you are enthusiastic you can add ball bearings, 5x2x2mm rear of motor, 4x2x2mm on brushplate
This page was generated in 0.318 seconds.
