Offline garben
#1 Posted : 05 June 2023 18:08:32(UTC)
garben
Hello.
Ok, math/geometry was never my strong point.
Is there an easy way or formula to calculate the length of a piece of curved C track? Looking to calculate the distance a locomotive is running between point A and Point B.
For example, the Marklin 20172 straight is 171.7 mm long. I can handle that. But what about a curved C track piece, like the 24130 which has a radius of 360.mm?
Thanks!
Norbert
Offline French_Fabrice
#2 Posted : 05 June 2023 18:19:24(UTC)
French_Fabrice
The formula to compute the length of a circle (circumference) is : PI * 2 * Radius.
In your case Radius is 360mm, and 30° = 1/12 of a circle ( a full circle is 360°)
So, length of a 24130 is : (3.14 * 2 * 360mm)/12 = 188.4 mm
Fabrice
thanks 5 users liked this useful post by French_Fabrice
Offline Martti Mäntylä
#3 Posted : 05 June 2023 18:35:03(UTC)
Martti Mäntylä
Double entry, remove.
- Martti M.
Offline garben
#4 Posted : 05 June 2023 19:18:37(UTC)
garben
The formula to compute the diameter of a circle is : PI * 2 * Radius.
So, lenght of a 24130 is : (3.14 * 2 * 360mm)/12 = 188.4 mm
Fabrice
Got it. So calculate the circumference of the particular track and divide that number by the number of pieces needed to make a complete circle.
I knew I should have paid better attention in school.
Thank you Fabrice!
thanks 1 user liked this useful post by garben
#5 Posted : 05 June 2023 20:39:52(UTC)
French_Fabrice
Perfect !
Sorry, I wrote "to compute the diameter..." ! It was not the diameter, but the circumference !
Hopefully, you've correctly understood what I was meaning...
I've fixed my post.
Fabrice
Offline revmox
#6 Posted : 06 June 2023 08:06:38(UTC)
revmox
I use online calculators like the one below when designing 3D bits for my layout.
Load up the radius of the curve and the angle and hit calculate. This one defaults to measurements in feet but it is easy to select mm.
https://www.handymath.co...n/arc18.cgi?submit=Entry
Answer looks like this -
thanks 1 user liked this useful post by revmox
Offline garben
#7 Posted : 06 June 2023 17:58:42(UTC)
garben
Perfect !
I've fixed my post.
Fabrice
No worries, I knew what you meant. Thank you!
Offline garben
#8 Posted : 06 June 2023 18:00:55(UTC)
garben
Oh great, I will check these out.
Thanks revmax!
Offline aos
#9 Posted : 12 June 2023 14:16:17(UTC)
aos
Hi Norbert,
You can download a free version Wintrack 16.0
This will enable you to click on any C track component and then by clicking on each end, it will give you the exact length.
Very simple and handy to use.
Regards, Alan
This page was generated in 0.409 seconds.
