Offline pBonavoglia
#1 Posted : 31 May 2023 17:04:10(UTC)
pBonavoglia
I am rebuilding an old Marklin system born in 1957 with M tracks grown through the years and in 2010 enlarged with C tracks and turnouts, digital decoders and the mobile station . Turnout decoders got digital addresses setting 10 pins on the card and the two digitized turnouts worked fine. For lack of space the whole thing was later dismantled and stored into boxes. Now in a new home with space I'm rebuilding and enlarging the whole.
I also bought a new turnout with a digital decoder and here comes the bad surprise: the new decoder has a ten pin set like before, but the coding is changed, pin 10 is used to commute from Mmx to CC, the others like binary numbers, different from old coding (2010) . I'm going mad, trying to configure turnouts from the old mobile station, nothing to do, the turnout does not give any sign of lile!
The instruction leaflets do not say nothing about this change of protocol and this is very bad!
Does somebody know a simple way to fix this problem?
#2 Posted : 31 May 2023 17:24:06(UTC)
It's not a problem. The old turnout decoders come with old coding tables that let you set the address.
The new turnout decoders come with new coding tables that let you set the address.
Set addresses 1, 2, and 3 and you're done.
#3 Posted : 31 May 2023 18:16:40(UTC)
The new decoders for turnouts are mfx and register themselves. I have several new ones including the three way decoder and all register without doing anything.
#4 Posted : 31 May 2023 18:28:52(UTC)
Do they do that with MS2 also? Or just with CS2 and CS3?
#5 Posted : 31 May 2023 20:50:12(UTC)
Good point Tom. No idea as I dont have a MS. May well be with a MS2 you have to set the address manually.
Offline pBonavoglia
#6 Posted : 31 May 2023 21:14:28(UTC)
pBonavoglia
Indeed it is a problem : of course the first thing I did was to set the new turnout using the new coding table: pin 1 2 3 on, all others off, that means number 7, but using mobile station and device no 7 the turnout does nothing ... even changing pin 10. I am still in the fog ...
#7 Posted : 31 May 2023 22:55:33(UTC)
What mobil station do you use?
MS1 or the new MS2?
Pin 10 are to set protocol for the turnout decoder, so if you use MS2 you must set protocol in the MS2 keyboard MM or DCC protocol.
#8 Posted : 31 May 2023 22:59:03(UTC)
MS2 cannot register mfx turnout or switch decoder.
You must use Pin codes on the m83/m84 if you use MS2 keyboard.
Offline rhfil
#9 Posted : 31 May 2023 23:25:56(UTC)
rhfil
Make certain that you are looking at the pins correctly. The numbers are very small and I once was activating the wrong pins. Also make sure you have thrown the pins completely. Throw them all off or on. I have found that making sure every thing is working correctly by first installing the turnout on a stub avoids tearing it out of a layout. Lastly I would go so far as removing the turnout completely from the layout and attaching it to the MS2 with nothing else and seeing if it works that way. This eliminates all other possible interference.
Offline pBonavoglia
#10 Posted : 31 May 2023 23:59:40(UTC)
pBonavoglia
MS1 or the new MS2?
As i wrote it is a MS bought in 2011, no number, so I presume it is MS1. So maybe is that is the problem ? I see everybody here has MS2 ... at least.Sad
I did many trials, pin up and down , nothing to do. With the old coding I had no such problem
#11 Posted : 01 June 2023 08:50:11(UTC)
MS1 cannot handle turnouts at all, so I presume it is MS2.
Four buttons left of the display, four buttons right of it, big red speed knob in the centre under the display, display is white on blue? That is MS2.
Offline ocram63_uk
#12 Posted : 01 June 2023 09:59:54(UTC)
ocram63_uk
a photo of the MS would clear all doubts 😊
#13 Posted : 01 June 2023 10:13:42(UTC)
And maybe a photo of the installed decoder.
Turnout decoders usually do not work if red and brown wires have been swapped. Red wire goes to "B" and brown wire goes to "0". Connect brown to "B" and most decoders will fail.
Offline pBonavoglia
#14 Posted : 01 June 2023 19:17:48(UTC)
pBonavoglia
On the web I found the same identical booklet, labeled MS2, or instance here: https://issuu.com/modelt...lub/docs/60653manual-eng
So I 'm even more puzzled. Shouldn't an MS2 have number 2 on the cover?
#15 Posted : 01 June 2023 20:02:43(UTC)
No. The info screen should show hardware version 2.0 or 2.1.
Mobile Station 1 shows "märklin systems" while Mobile Station 2 shows "märklin digital".
Offline pBonavoglia
#16 Posted : 01 June 2023 20:38:06(UTC)
pBonavoglia
Here are a few photos
Mobile Station
#17 Posted : 01 June 2023 20:51:38(UTC)
I only get error 404.
Offline pBonavoglia
#18 Posted : 01 June 2023 21:23:31(UTC)
pBonavoglia
For some reason this system does not show my photos. Too large?
Online marklinist5999
#19 Posted : 01 June 2023 21:26:12(UTC)
Doesn't load! Icon just spins
Offline pBonavoglia
#20 Posted : 01 June 2023 21:35:51(UTC)
pBonavoglia
For some reason this system does not show my photos. Only link to photos, just click on them to see them in large.
Mobile Station
Instructions
Pins
thanks 1 user liked this useful post by pBonavoglia
#21 Posted : 01 June 2023 22:07:22(UTC)
Clearly, you have an MS2.
Offline pBonavoglia
#22 Posted : 01 June 2023 22:29:14(UTC)
pBonavoglia
Ok, thank'you, but what it means? Do I have to buy a CS3 to get the new decoders working?
#23 Posted : 01 June 2023 23:32:03(UTC)
Although you will get a lot of help on here I would suggest you buy the Marklin book on their digital system. It covers the MS and CS3 plus all the other digital items and explains how they work and how to connect them. It is a mine of information on Marklin digital.
#24 Posted : 01 June 2023 23:57:06(UTC)
The MS2 can control turnout decoders. The issue you have is that yours likely isn't updated with the latest software version, and that can limit what it can do. You need a CS3 to update it, or find someone who has one.
However, it's worth a try to put yours into the DCC protocol, and try loading the turnout decoders manually. Not only using the digital book, but referring to Youtube tutorials by "Modeltrainfun", etc. I found him by Googleing "how to" ......... on a Marklin MS2, etc.
#25 Posted : 02 June 2023 06:17:00(UTC)
I must tell to you that never ever have power switch on if you shall switch pin codes in the m83/m84. Märklin recommended it. Read careful manual of the m83 and the MS2.
#26 Posted : 02 June 2023 06:40:47(UTC)
I don't think that's an issue here if the old turnouts work.
That's not true.
@pBonavoglia: You do not show how the new decoder is connected to the track. It will not work if red and brown are swapped or yellow does not connect to "B" (centre rail).
Offline pBonavoglia
#27 Posted : 02 June 2023 18:14:23(UTC)
pBonavoglia
That's not true.
Ooops the yellow cable! I thought it was there for the light, that was something new and strange. Why two cables, red and yellow, going from the same card to the same potential (B third rail)? It id difficult to guess why, but now it works! And that is what matters. Thank you very much!
#28 Posted : 02 June 2023 18:47:29(UTC)
Yellow is the power for the motor. If you have many turnouts, yellow can be connected to an external power supply to reduce the load on the digital track current.
Jay
#29 Posted : 03 June 2023 00:08:54(UTC)
That's not true.
I believe he was talking of updating an ms2 Tom, and i would agree that currently access to a cs2 or cs3 is required to do so.
#30 Posted : 03 June 2023 14:36:57(UTC)
I knew it Alan!
#31 Posted : 03 June 2023 14:37:55(UTC)
That's not true.
The update can be transferred from MS2 to MS2, so neither access to CS2 or CS3 is required to do the update.
But it is definitely not true that a CS3 is needed for the update, right?
#32 Posted : 03 June 2023 14:55:59(UTC)
Ok, but the transfering MS2 must be updated by a CS2 or 3. He has neither, so he needs someone with a current version MS2 at least.
Offline pBonavoglia
#33 Posted : 03 June 2023 23:09:10(UTC)
pBonavoglia
Okay, now having connected the yellow cable to B everything works fine, so I do not need to update to CS3 or MS3.
On the contrary it seems that one of my big problems in rebuilding this Marklin system, the tangle of cables needed to control all the switches, now three C-type and ten M-type, may be solved without throwing away all M-tracks and turnouts, and buying the C-equivalent.
Using 74491 Electric turnout mechanism for C-track and a 74462 Built-in digital decoder (C-track), the same used for the C-turnout, I was able to digitize an old M.turnout, see photos:
M-turnout digitized
M-turn is now working
I would like to know if someone did the same thing, and how.
At first I didn't want to use the soldering iron, for various reasons, but in the end I had to resign myself to it; this is the only way to get good quality contacts. Then I had to play with bits of cardboard and double-sided tape to best position the mechanism.
But maybe, opening a new topic is more appropriate,
Offline pBonavoglia
#34 Posted : 03 June 2023 23:14:56(UTC)
pBonavoglia
#35 Posted : 04 June 2023 16:59:17(UTC)
Glad you sorted it out!
#36 Posted : 04 June 2023 18:13:41(UTC)
The issue was resolved without updating the MS2. There can be a long update chain of MS2s with CS2 or CS3 at the end. Knowing all update options (MS2, CS2, CS3) makes it more likely to happen when an update is needed.
But when two decoders work and the third one does not, then it is very likely that it can be resolved without update at all.
Guest (7)
This page was generated in 1.024 seconds.
